Spend my 2K
Old 01-18-2012, 08:03 PM
danbrazda's Avatar
Default Spend my 2K
2001 WS6
400 rwhp, 383tq
228/228, 566 cam
1-7/8 long tubes, 3" to the rear
stock heads ported/polished
410 gears in 10 bolt rear
T56 stock
Monster Stage 3
Lightweight flywheel
Tick Master Cylinder
Baer Eradispeed drilled slotted at all 4 wheels
Hankook Ventus 275/35/18s all 4 corners
Best way to spend 2K for more power while staying as driveable as possible?
Old 01-18-2012, 08:20 PM
Rare96LT1Formula's Avatar
Who ported the heads? Those numbers seem low for your mods. Spend $100 and have them flow tested imo. If there is anything to gain there (which I'm guessing there is), spend your money there + retune/dyno.
LS6 intake on your car, right?
Old 01-18-2012, 08:21 PM
arock24's Avatar
I would look into a rear end. Any more power with your m6 and you'll be replacing it anyway.
Old 01-18-2012, 09:07 PM
zracer323's Avatar
Sell your heads and get some Trickflow or AFR heads
Old 01-18-2012, 09:18 PM
TImmy_Jones's Avatar
SFCs and suspension.
Old 01-18-2012, 09:38 PM
The Mighty Texan's Avatar
Send it to me so I can I would say a rear end also.
Old 01-18-2012, 09:42 PM
2cat95ta's Avatar
I say suspension, you will see some nice gains there
Old 01-19-2012, 07:45 AM
danbrazda's Avatar
Forgot to mention there are already a lot of suspension upgrades- it corners like a dream.
Yes it has an LS6 intake.
Definitely need to do a flow test.
Previous owner in Chicago had the head work done- not sure where exactly.
Didn't think I could do a new rear end for 2K but I'll look into it. I don't run it at the track so the street tires don't really hook up enough to blow out the 10-bolt (has a TA girdle on it).
Old 01-19-2012, 05:05 PM
zracer323's Avatar
A new rear end is going to cost more than 2k. If you don't drag race, then I wouldn't worry about it.
Old 01-19-2012, 05:08 PM
JUSTINSWS6's Avatar
You dont have to dragrace to break a rear. I would sell your heads and buy some afr or prc heads.
Old 01-19-2012, 05:12 PM
ULTIMATEORANGESS's Avatar
nitrous.
Old 01-19-2012, 06:56 PM
BStowers023's Avatar
Power is about right for his mods.
The T56 will hold up for a while, I'm making much more than him and mine is fine.
Originally Posted by ULTIMATEORANGESS
nitrous.
This, Drag radials and some front suspension.
Old 01-19-2012, 08:48 PM
arock24's Avatar
I wasn't meaning the transmission wouldn't hold up. I was referring to the manual transmissions going through rear ends like there's no tomorrow, especially when making 400+hp
Old 01-19-2012, 08:53 PM
JUSTINSWS6's Avatar
Yes the rear will go ka-boom for sure. There are good 9 inches for sale for under 2000k.
Old 01-21-2012, 09:48 AM
If you aren't drag racing and have decent suspension the rear is fine.
Old 01-21-2012, 10:25 AM
hiram007's Avatar
Agreed. The rear is the way to go, especially if you already have the suspension. All that power has to go somewhere, otherwise, increasing it would do nothing for you once that ten bolt snaps like a twig. Mine broke and I was close to stock power with LT's and exhaust. Get a 9in or, since you dont drag, a 12 bolt.
Old 01-21-2012, 10:20 PM
I8UR4RD's Avatar
id start with suspension. get that 60 foot down, but you prob need a rear end first anyways, because the lca etc...will add even more stress on the 10 bolt and it will go out quick.
if not then i would go with a better set of heads. tf or afs.
or you could buy a forged motor kit and get ready to throw on a 200+ wet shot.
