Finally got one!
Old 02-18-2012, 03:41 AM
dnapier4's Avatar
Default Finally got one!
I know this is a repetative question for noob's, however I have to ask. I just picked up a 2004 Pontiac GTO. 41,000 mi, 6spd transmission. It is all stock. Immaculate condition. My question is since I want to mod the car, should I keep the LS1 and do the H/C/I, forced induction, or go the LQ9 route and start there? It's gonna be pricey no matter which way I go, but I want suggestions, opinions, etc. Thanks in advance.
Old 02-18-2012, 05:52 AM
82cetuner's Avatar
theer is no reason to step up to the LQ9 unless you plan to bore it out or you have a seriouse desire to use ls3 heads.
the ls1 is a good motor and with good heads and cam can make over 500 hp so the question is where is your HP goal
Old 02-18-2012, 06:22 AM
ULTIMATEORANGESS's Avatar
if your motor is ok id go with a H/C/I upgrade.
Old 02-18-2012, 06:34 AM
camaroboy14's Avatar
Pics? And congrats on getting a GTO I would also go H,C,I
Old 02-18-2012, 09:28 AM
silver04goat's Avatar
Welcome i picked 04 gto a cpl weeks ago.I wouldnt change from ls1. These cars can make plenty of power
Old 02-19-2012, 12:02 AM
dnapier4's Avatar
Thanks for the advice. As far as HP goals, as much as reliably possible on the stock bottom end. I want it still decent to drive. I would like to have a low 12, high 11 sec goat, so I can hang with or beat my friends 03 cobra, and my cousins 10 gt500. The 2 things I have over them is, I can out drive them, and I own an ls motored car.
Old 02-19-2012, 07:20 AM
MonmouthCtyLS7's Avatar
It all depends on how deep your pockets are...41k is light mileage. You could run heads/cam,if you want to supercharge and plan on running anymore then 8 pds then you might wanna look into one of the iron LQ blocks and or forged internals...You could also build a budget stroker w/ the LQ block....and if your planning on hanging w/ a modded Termi or GT500 (especially on the street) most H/C/I setups aren't going to cut the mustard.
Old 02-21-2012, 11:59 AM
mjs1012's Avatar
Keeping the ls1 will be cheaper of you think about it because you won't be buying another motor....
Old 02-21-2012, 01:04 PM
Sales@Tick's Avatar
Hey bud. Sounds like you have the performance blood like the rest of us have. Congrats on the purchase of the GTO. There are many different options you can go with. It is going to depend a lot on different factors. Are you wanting a nice cam sound or are you looking to make high horsepower? I see really no need to pull the ls1 if it only has 41K miles. If you do some sort of boosted setup, you can always put a forged rotating assembly later on in the ls1 and make good power on higher boost levels. I encourage you to check out our site, we offer many options for your GTO.
http://www.tickperformance.com/categ...6-Pontiac-GTO/
Old 02-21-2012, 07:53 PM
88blackiroc's Avatar
Depends on your budget. If it were me and money weren't to big of a concern, id go lq9 with forged internals and a turbo/supercharger. They can be had pretty cheap and you don't have to worry about warping(even though its not much of a concern until you hit 800 or so hp). Or you can get the ls1 with some forged pistons/rods and throw a power adder on and be set. Its kinda of a either/or situation. Both routes are stout and have proven time and time again.
If you don't stay n/a id at least go with some good internals so you don't have to worry about it when you crank the boost up
Old 02-21-2012, 07:54 PM
CamaroSS27's Avatar
Congrats but like everyone said for much cheaper keep the ls1 and H/C/I
Old 02-21-2012, 10:49 PM
raysadude's Avatar
Congrats on picking up the goat OP if I were you I'd go with H/C/I with 9" rear end, twin disc clutch and top notch suspension setup and throw 200 shots on top of it that should take care of those pesky cobras and GT500. Boost can get really pricey.
