motor mount swap
Old 02-21-2012, 04:48 PM
wicked383lt1's Avatar
Default motor mount swap
How hard is it to swap stock vs poly mounts? Someone told me I have to cut the rivets off and stuff. All input will be very much appreciated. I changed out my stock shorties for LTs. I know that I should've changed them...
Old 02-21-2012, 08:12 PM
CamaroSS27's Avatar
I dont think you have to cut anything from what I have heard.
Old 02-21-2012, 08:52 PM
Do you know where I can get the three mounts for our cars?
Old 02-22-2012, 04:40 AM
sjsingle1's Avatar
you have to remove the rubber out of the metal shells to install the poly mounts..............which requires drilling out the rivets of the stock shells.........they are then held together with bolts
Old 02-22-2012, 04:41 AM
sjsingle1's Avatar
Old 02-22-2012, 04:43 AM
sjsingle1's Avatar
Old 02-22-2012, 12:18 PM
mikh338's Avatar
thinking about doing mounts soon myself. my motor rocks a lot with the stock rubber mounts, i know the cam is a big part of it but i have been told with diff mounts they will rattle my teeth out. anyone agree or disagree?
Old 02-22-2012, 01:03 PM
sjsingle1's Avatar
i have NO vibes with poly MM and poly tranny mount..........your mileage may vary
Old 02-22-2012, 02:44 PM
mikh338's Avatar
i have not researched the mounts yet, what brand are you running?
Old 02-22-2012, 02:47 PM
sabersaw30's Avatar
Helps out alot with good motor mounts.Love my solid mounts.
Old 02-22-2012, 07:38 PM
Where did you get the mounts from? Anyone else chime in if you can help.
Old 02-22-2012, 10:07 PM
sjsingle1's Avatar
the polys are prothane............and the mounts are spohn
Old 02-23-2012, 01:52 PM
Where can I get them at a good price?
Old 02-23-2012, 02:12 PM
mikh338's Avatar
ive been looking myself and ebay has been the best so far.
Old 02-23-2012, 05:44 PM
sjsingle1's Avatar
got the polys from summit.....i forget the price
Old 02-24-2012, 07:45 PM
railmule's Avatar
you got to "drill" out the old rivets and the old rubber mount is melted in the clamshell you gotta scrape it out.. its a pita but the only thing thats gonna make the headers stop banging the floorboard when you get on it...
got mine from jegs...
http://www.jegs.com/i/Prothane/311/7-512-BL/10002/-1
good write up on a MM swap...
https://ls1tech.com/forums/generatio...otsa-pics.html
Old 02-24-2012, 07:50 PM
sepsis's Avatar
I got mine from Summit, Prothane.
They were the same price from Jegs. They were the lowest I've found.
Old 02-24-2012, 08:11 PM
Thanks for all the help guys!
Old 02-24-2012, 08:59 PM
justin hover's Avatar
^^I printed out that write up and gave it to my guys at the shop last week..They swapped out the old mounts and installed the new polys in 2hrs. No horror stories. I couldn't tell any difference...Then again my stock mounts were in perfect shape, and I added my full exhaust. Glad I have them though.
Old 02-24-2012, 09:03 PM
Were your headers banging underneath the car?
Quick Reply: motor mount swap
