Wanting to go with new head's/cam 02 LS1- Noobie Questions
Hey all, I'm just looking for some references as to what people are running as far as a head/cam set-up goes for a 2002 Camaro SS. My car is currently sitting at 84k miles so I'm curious if it would be worth doing at this stage or what differences that might make on what I would need to look at. I'm looking to add power and am just needing some help on what exactly I would need to purchase/replace to get some good power gains. I'm planning on doing this install myself also, and I do remember seeing a forum on here somewhere explaining the installs so if I could even get directed to the right place that would be awesome. Thanks for the time reading- Jordan. Oh btw it's an automatic, only mods currently is an SLP Loudmouth Exhaust system and an SLP air lid..
Long tubes
Ory
Ported tb
Then I would upgrade the stock clutch and the 10 bolt. Unless you want to wait until they go. There are so many heads/cam options you have to be more specifc to what your goals are. If I were to get a heads and cam setup for a street car I would def call texas speed and find a good tuner.
Well tbh I am just looking at the best power gains for the $, I've heard it alot though that when your thinking header's/working on header's if you have the money/resources to look into a new cam at the same time that it's best to knock them out together. As far as a specific goal goes though it's power gains for sure. Thanks for the imput so far guys keep it comin! I've been referred to Texas-Speed.com asfar as parts go but still open to suggestions.
1 Post
Texas Speed has a lot of great deals but check our other sponsers also on prices like Un Speed,Speed Inc Ect .I spent $2300 on my 02 Camaro SS Auto in just bolt-on's and ran 11.80 @ 114 on Nitto 555R Drag radials and even had Heads & Cam but never put them on cause i was happy w/ my times w/ just bolt-on's !
Makes sense so far thx fellas, it's probably bad that I have to ask, but can you guys be specific on which bolt-on's your referring to? I'm really new to this whole thing, but really want to learn. I've got about 2k to spend on parts though so j/w what you guys would do first in the bolt-on dept then if that's the approach im going to take.
Headers: http://www.texas-speed.com/p-3516-te...e-headers.aspx
ORY: http://www.texas-speed.com/p-293-tex...ad-y-pipe.aspx
Now after you get headers your current exhaust will sound like CRAP, so you will need a new one. I suggest Magnaflow. Most vendors should sell this so i'll leave it up to you where you want to get that... Should cost UNDER $475. Do not pay more.
Thats about 1k... plus little things like plugs/wires, motor mounts, etc. while ur in there.
The other 1k I would use to buy urself a stall. A stall wakes up an automatic like you would never believe. It will no joke shave 1/2 a sec off your 1/4 mile time. I suggest a 3600 stall from Yank or any other big name company. You might want to replace the flexplate too while ur in there.
After this u will want a tire to help you grip... and you should be pretty happy for a little while with this.
