Lights flickering like strobe light, volts above 15, HELP!!!!
Old 04-02-2012, 08:40 PM
kevintkrebs's Avatar
Default Lights flickering like strobe light, volts above 15, HELP!!!!
In the morning whe i start my 02 ss, the volts sit in between 15 and 16, and my headlights, dashlights, and tail lights flicker like crazy. after about 15 or 20minutes of driving, they settle at about 14. I have no trouble starting the car, and I hooked up a voltmeter to the battery, off it reads 12 and change and on about 15 when it first starts in the morning settling down to 14 and change again after about 20 min of driving, also tested voltage regulator and sat at 14 as well. was told to unhook neg post when car is running and see if it shuts off which it didnt. Any suggestions PLEASEEEE!!!!
Old 04-02-2012, 09:07 PM
S8ER95Z's Avatar
Did you test it while it was flickering or after it straightened out? I'm thinking alternator/regulator.
Old 04-02-2012, 09:09 PM
Both, 15 and above while flickering
Old 04-02-2012, 09:12 PM
S8ER95Z's Avatar
All of your body grounds good?
Old 04-02-2012, 09:21 PM
I'm not sure, i don't really know too much about cars, I know theres one from batt, but others not sure where to look, tryin to learn
Old 04-02-2012, 10:38 PM
twitch32's Avatar
Is it possible that the vehicle has under drive pulleys on it that you didn't know about? It seems that under drive pulleys can cause the lights to "flash" after you start the vehicle until the system voltage stabilizes.
Old 04-02-2012, 10:53 PM
sixvi6-camaro's Avatar
Alternator.. there are multiple threads on this in the general tech section. Its usually a bad voltage regulator... which is inside the alternator.
https://ls1tech.com/forums/general-m...ed-my-alt.html
Old 04-02-2012, 11:11 PM
Vortec53's Avatar
I'm with the last guy. replace the alternator cause it contains the voltage regulator
Quick Reply: Lights flickering like strobe light, volts above 15, HELP!!!!
