First ls1 car, whoop
Old 07-20-2012, 02:46 PM
98coop's Avatar
Default First ls1 car, whoop
Long time no see for this site for me, lol.
I finally got my paws on an ls1 car, a 98 z28 a4 with 175k on the clock.
I've only got $550 in it, lol
It runs pretty well, but has a few querks...
\Problem number 1: The check valve is in the fuel pump is supposedly bad, which causes the line to lose pressure when the car sits. you've got to cycle the key twice to get it to start. Is this a common problem? And i'm assuming the only way to fix it is to replace the fuel pump.
Problem number two: The oil pressure guage bounces around quite abit at cruising rpm. At Idle it holds pretty steady around 30-40 psi, and under full throttle it holds constant at a little above 40. I'd say it probly fluctuates 2-5 psi, pretty rapidly back and forth. I almost think it's a the guage, but figured I'd ask if this also is a quick fix, or a hint of something more serious.
Old 07-20-2012, 03:18 PM
usnfenix's Avatar
i may be incorrect but i think theres no issue with your oil pump. sounds like the oil gauge. the gauges in the f body were shitty and inaccurate anyway.
Old 07-20-2012, 03:26 PM
lt1pwr1's Avatar
\Problem number 1: The check valve is in the fuel pump is supposedly bad, which causes the line to lose pressure when the car sits. you've got to cycle the key twice to get it to start. Is this a common problem? And i'm assuming the only way to fix it is to replace the fuel pump. Only way to fix is to replace the pump.
Problem number two: The oil pressure gauge bounces around quite abit at cruising rpm. At Idle it holds pretty steady around 30-40 psi, and under full throttle it holds constant at a little above 40. I'd say it probly fluctuates 2-5 psi, pretty rapidly back and forth. I almost think it's a the guage, but figured I'd ask if this also is a quick fix, or a hint of something more serious.
http://i235.photobucket.com/albums/e...op/camaro1.jpg
First of all, how is the body? Hell of a deal you got there regardless!
Yes, sounds like the check valve is bad on your fuel pump. I wouldn't worry about it and just run it like that until the pump goes (annoying as it may be).
Second, yes the oil pressure sensor is behind the intake and commonly goes bad and will make your gauge fluctuate as you described.
Old 07-20-2012, 03:28 PM
usnfenix's Avatar
and if it isnt bad youll prob break it taking the intake off to replace it anyway.
Old 07-20-2012, 03:34 PM
transamtom's Avatar
Might as well do an LS6 intake while your changing the OPSU,but that would almost double the price of the car
Old 07-20-2012, 03:40 PM
NC98Z's Avatar
Question
Am I the only person on this forum that has replace the OPSU without taking the intake manifold off? All you gotta do is get a thin walled sensor socket from NAPA and about 15 minutes of your time. Lay you a packing quilt across the LS1 and proceed.
Old 07-20-2012, 03:41 PM
2win_SS's Avatar
You paid $550 for that car?
Old 07-20-2012, 03:46 PM
98coop's Avatar
Lol That's a relief about the opsu. I was hoping it was something simple. And I probably will run the fuel pump until it breaks for good, I was just curious if That's what it actually was.
I'd like to get me an ls6 intake and a cam for it asap.
What would y'all recomend for a good cam for an auto car with a nasty lope?
LT1PWR1: The body is pretty straight, It's got a little bondo in the passenger quarter panel, and the clear is peeling in a few spots. pretty straight though. I've been trading up with guns and cars and this is the latest development lol. I may hang on to this one for a while
Old 07-20-2012, 03:47 PM
98coop's Avatar
I have 550 in it. I traded a 44 mag for a truck, and traded up a few times, now Im in this car. I had 550 in the gun more or less.
Old 07-20-2012, 05:35 PM
RADEoN's Avatar
i'm selling an LS6 intake with fuel rails and injectors if you're interested. PM me if so.
Old 07-20-2012, 11:59 PM
98coop's Avatar
Well I took it Middle tn dragway tonight, and it ran a best of 9.74 at 74 with a 2.33 60' time. That is absolutely miserable, lol. But that track runs uphill pretty steep, and everyone was running about a second off of what they usually run due to the humidity and temp. So I'm hoping for a 8.90 9.0 ish pass at a flat track when it cools off. Still had a blast and had the fastest car on street tires(sadly lol).
Old 07-26-2012, 12:14 AM
Zlow28's Avatar
get some stickier wheels and suspension mods to drop those 60 times. Congrats on the ls1 btw. You might want to get a second opinion on the oil pressure. I know the gas gauge usually reads bad, but ive never heard of oil pressure guages not reading properly on ls1 cars. I could be wronf though.
Old 07-31-2012, 03:08 PM
waxenate's Avatar
Dude! I thought I got a hell of a deal when I bought an LS1 engine for 500! Way to go!
Old 07-31-2012, 03:09 PM
waxenate's Avatar
Go ahead and check the oil press....not worth messing up a 5050 LS1!
Old 08-03-2012, 12:18 PM
jose946spd's Avatar
I'm so sketchy about trading cars idk if I could do it. In ur case tho, looks like you did good.
Old 08-03-2012, 12:49 PM
camaroman08's Avatar
Do you plan on DDing the car or do you have another DD? It depends on what you plan on using it for as to what a "good cam" for your car is.
Old 08-03-2012, 09:45 PM
I8UR4RD's Avatar
the oil pump is spinning via the crank...the faster the crank turns....the more pressure you get. if it starts dropping....then you can start worrying.
drop the rear and take that tank out.
or just cut a trap door in it since its only $550 worth of car.
Quick Reply: First ls1 car, whoop
