Just bought a low mile 99 Z, what should I replace?
Well I bumped into a bad *** original owner and well documented 99 Z28. Car still smells new, the undercarriage looks incredibly clean, and it
has all original parts on it....down to the tires and belts, brakes, etc.
The guy was an older retired gentleman in his mid 60s who only put a few hundred miles a month to keep the seals wet and from drying out. So no problems there. But as far as tires, brakes, and belts, what else should I be looking at replacing? It's an auto with a little over 28k on it. Valvoline synthetic all its life.
Shocks? Struts?
I ask about those because it actually feels and rides very smooth to me.
Thanks! Pictures soon
Shocks? Struts?
I would get new tires because they probably are dry rotted after 15 years. It wouldn't hurt to change the fluids and check the belts for cracks. Sounds like a great car with low miles. Enjoy!
Location: Illinois, as close to "Normal" as I can get...
If it feels good leave it alone. Get new tires though, if anything is gonna go that will be the 1st.
My suggestions are in my siggy...
LS1Tech Administrator
Received 1,796 Likes
No need to worry about shocks and brakes if they feel fine, unless you just want to upgrade the shocks for better than stock performance. Fluids/tires/belts would be the main order of business IMO. Even the hoses are probably OK (mine are still original on my low mile '98, and they are not cracked/dried/shrunk/spongey/etc., but I do keep them treated with 303).
Belts are simple to change, and see a lot of stress, so you might as well just do them. Z-rated tires can remain serviceable for a pretty long time when stored indoors, but with nearly 30k miles (plus all those years) I would replace them at this point.
Again, brakes shouldn't be worried about unless there is something wrong with them. Brake fluid is a different story though, if you have the urge it wouldn't be a bad idea to change the fluid. FWIW, my '98 still has the original rotors and pads with only 16k on them....and they have a ton of life left. The slide pins could stand to be re-greased though, yours might be the same.
I would definitely do a coolant flush. Maybe twice.
Thanks for the suggestions guys. So as soon as I get her legalized tomorrow morning, the first thing to replace will be the tires and the belts. I just checked the motor oil and it looks and smells fine to me. But if you all still think it should be changed, I will.
I also noticed a real slight sag in the back rear by the tire on the passenger side...im guessing a sagging spring or a strut?
It's not mine! woo hoo!
I'll "second" the suggestions here: belts, fluids, and maybe tires (if you notice any cracking or dry rot). I'd also suggest inspecting the air filter, changing the fuel filter, and changing the PCV valve. If it has the power steering cooler, then I'd also remove that and simply replace with a upper hose from a non-PSC car.
