P0300
P0300
Well I got the dreaded P0300 code, I have a 2001 WS6 m6, has slp lid ,long tubes,no cats. Car was running fine went to a cruise in, when I started it back up to leave it had a mis to it. I have replaced the plugs and wires,and also a bad o2 sensor. Car still has mis in it. The 4 plugs on the driver's side was **** black and the 4 on the passenger side was white and looked normal. Any ideas what my problem could be??? Thx Wayne
wow i cant believe this post has had 183 views and not the first reply!!!!! i thought this forum was to help people who have problems with there ls powered vehicle??? thx for nothing !!!!!!!!!!!!!!
Assuming the plugs and wires are all good since they are new, I'd look at fuel related issues.
What's the fuel pressure?
Any reason to believe it's bad gas? water in gas? Take a sample
I would also recommend a good fuel injection cleaning. Not the cleaner you dump into the tank, but one you put into the fuel rail. We used this when I was at the dealer. Or find a shop that has one similar to this https://www.otctools.com/products/fu...cleaning-kit-0
If a single coil was going bad, I would expect to see a P0301 to P0308 code. But it doesn't appear you have those codes
Is there no other check engine codes?
--Kyle
--Kyle
We help those who help themselves
I believe this forum is for those who help themselves. Asking for help then getting mad when someone didn't answer is backwards. Most people on here won't answer posts that ask questions that should have been researched first. A simple search of p0300 would tell you that it means random cylinder miss fire. I doubt your o2 sensor was bad, or that you needed to change your plugs/wires. You need to smoke the engine for vacuum leaks.
LS1Tech Administrator
Received 1,492 Likes
Further scanning is in order. If the problem is fouled plugs on the driver's side only, and all four of them, then you can isolate the issue to the ignition or fueling on that side of the engine. I'd scan the LTFT (long term fuel trims) on that bank and see what's happening. Also scan for cylinder specific misfires on #'s 1/3/5/7. Check wiring at the coil pack rail to make sure there is no loose or weak connection. Is this the same side that has the replacement O2 sensor?
Glad to hear I was jumping to conclusions. It sucks running into a faulty parts, which seems to happen more often than it should. I've gotten to the point to test new parts before I install. I hope your issue is solved for good.
