Can installing an SLP Intake Lid cause a rich burn?
I recently installed an SLP intake lid (new) onto my Z/28 LS1. Everything seems fine but eventually a couple hours later I got a "Service Engine soon" light and you can smell a rich burn from the exhaust. I disconnected the battery and PCM Batt fuse for 5 minutes, and reconnected it. However it still smells rich and the service light it on (I'll go get it looked at by Autzone tomorrow for the code). My mechanic friend said that the extra airflow from the lid cusses the MAF to freak and start burning rich to compensate for the extra airflow. He said I might have to disconnect my battery for a few hours and let it fully reset. If that doesn't work he says to just put the stock lid back on.
What do you think, could it be the lid and do I just need to disconnect the battery longer?
I think the connectors are tight but I'm not sure about the leaks, the rubber gasket for the air hose that came with the lid seemed to wiggle too much. Same with the temp sensor.
LS1Tech Administrator
Received 1,492 Likes
I'd get the code checked and then go from there. But I can tell you from first hand experience, after installing lids on dozens of LS1 F-bodies over the years, this won't cause any codes or freak out of the MAF.
The lid certainly didn't cause your problems - if it did, then thousands of other LS1 owners would have experienced the same thing as a lid is the most common modification done to these cars. However, there may have been a marginal connection or wire, or sensor damaged, or some other factor (such as a crack/hole developing in the air bellow during install, or something like this) that occurred during install to now be causing issues with A/F ratio and/or the SES.
if anything the added cold air would lean it a bit although the maf sensor if clean will detect the colder/denser charge and enrichen based on the data collected by the sensor. Cleaning the maf sensor with CRC maf sensor cleaner is always a good idea if you have no idea when it was done last , it gives the sensor the best opportunity to collect accurate intake charge data and from there the tune will reference how much fueling to supply for the collected intake charge data.
The more changes made the more likely any car could benefit from a tune but for just a lid if your having issues its not the lid causing it but as others have mentioned it could be related to the install of the lid damaging a sensor or allowing it to collect in accurate data due to a tear , leak ,etc...
