What is a good book on LS engines
I was a pushrod Ford person for along time. I have just started messing around with LS cars. Is there any one book that stands out as far as interchanging parts, best mods, best heads, and so on? I have a 2000 Z28 auto with low miles I am working with. I did the usual converter, gears, lid, cat. back, drag radials, and it runs low to mid 12's. Headers look like a bit of a PIA, but I have read LS cars respond well to them, so they will likely be next. Also on F bodies are subframe connectors necessary? Will the rear lower control arms damage their mounting area with-out them?
This is a good one I picked up a few years ago... http://www.ebay.com/itm/HOW-TO-BUILD...wAAOSwbdpWZB0z
Headers are good to unlock some power on the F-bodys but you'll need to do the entire system to see the full effect. The stock cat back is a restriction too. Sub frames are a must on my list as well, the car is alot stiffer since welding them in. You don't damage the lower control arm mounts with out sub frames you twist the body of the car and the rear quarter panels will pinch and bulge.
I'm not a fan of sub frame's. To work they half to be heavy. Though I do have a set in the garage and there waiting on a nitrous system and slicks. I have had no issues without them and using stock lca's and bushings that I'm keeping an eye on @ 1.6 60 ft and nitto 315r's. They only hook up in one run out of 5 at the track that's closest to me. Going to NT05's.
If some of the haters are so black and white to think I'm recommending this as the LS bible... Good for you guys.
