car falls on its face after 5k rpm
So i take my camaro out the other day out to my local road to make a pass, and just as i hit 5k rpm's it completly stopped making power and just made noise. its a heads,cam, spray w/a nitrous tune on it and usually makes power all the way up to 6800 rpm, I put new plugs in it and a new fuel filter and nothin still fucked up. any ideas what this could be?
Originally Posted by BlueSix
Valve float? What springs are you running and how od are they?
Moderator
Without wideband readings (or at least in-car O2s)
it's hard to say for sure, but this is how COT (cat
overtemp protetion mode) acts - big excess fuel
dump once the PCM thinks the cats may be in
trouble from too much heat.
Then again, I have found another way to get this,
a torque management related "shift hang". But you
would have had to be messing around your shift
tables, torque management profile etc. to get into
that situation.
But on an untuned vehicle, my money's on COT.
that situation.
I don't have as much done as you, but after i put the janzter TB on, i had the same thing happen. We put it on the dyno and found that it started pinging at 5k and lost 40rwhp from 5 to 6k. We added fuel up top and [Emeril]BAM![/Emeril] it was fixed. my .02
