Questions about Seafoam(already did a search)
I just changed my spark plugs a couple weeks ago, after using the Seafoam will they need to be changed again? I did a search and it seems like there are some mixed opinions.
Also, I noticed that most people say to change the oil 100 miles after using the Seafoam but would it be okay to change the oil immediately afterwards instead of waiting 100 miles?
I wouldn't wait 100 miles. I changed mine within 20 miles. This is assuming you put it into the oil. There are different uses for it. One is to put it in the oil, the other is to suck it in through a vacuum line and into the top end. If you put it into oil it won't affect plugs, if you put it through vacuum line it won't get into oil. (idealy anyway, lol) Of course, you can always do both.
They each do their own thing. On a 98 that apparently hasn't had it done in awhile, if at all, I'd just go ahead and do both. Cleaning the top end via a vacuum intake seems to be the most common method. Supposed to help burn off carbon depsits and the like. Using it in the oil is supposed to get sludge and crap out. it messes with the viscocity of the oil though, I think, so I wouldn't drive it hard or far/long with seafoam in the oil.
oh i see...well i suppose having 101,000 miles on mine and it never has had it happen i should do it huh...haha...i need two cans? one for the pcv and one for the oil?...i have one can already just wondering if i need to get another...i'll prolly end up just doing the pcv hose and leave it at that...
Originally Posted by 777
can you just wait to see if they go bad afterwards? i'd rather not go through all of the work when it is not necassary
Yes, pulling a couple of them. I'd worry that it is reduced but not enough to notice. If you are going to worry about it, that is. I suppose it is very easy to pull the #1 and #3 plugs. That wouldnt be a bad way of doing it.
Okay, I just Seafoamed my car and I'm getting ready to change the oil now. After using the Seafoam I noticed a ticking noise at WOT that sounded like it was coming from the drivers side. It mostly went away but I can still hear a faint ticking when I really get on it. Is that normal?
