An LS1 is an LS1 right?
Old 02-02-2006, 10:58 AM
JDJP's Avatar
Default An LS1 is an LS1 right?
Whats the difference in the 1998 corvette LS1 and the 98 LS1 they put in the firebird and camaro? how does it rate with 45 more HP?
And how much know how would it take to swap a 98 vette engine into a 99 TA? What problems would you for for after a swap like that?
JD
Old 02-02-2006, 11:03 AM
DONAIMIAN's Avatar
There is no difference in the motors, the vettes came with dual exhaust that gave it a little more power, and less weight than an f-body. Also the vette didnt have EGR on the intake, and I belive the fuel system is a little different.
I would say no to putting a 98 motor in anything. Hell I advise against even buying a pre 99 car. Some of the 98 motors had bad oil pumps that failed, and the heads/valvecover arrangment was changed in 99 to a better design.
Old 02-02-2006, 12:24 PM
rednecks70's Avatar
I thought vettes came with an LS6? They have better flowing heads and intake, but the short block is the same as an LS1.
Old 02-02-2006, 12:29 PM
~RedLineLs1~'s Avatar
An ls6 only came in the c5 z06. The c5 got an ls1.
Old 02-02-2006, 12:44 PM
rednecks70's Avatar
Thanks for the correction.
Old 02-02-2006, 12:49 PM
JDJP's Avatar
are the 98s really that problematic?
I have a 98 TA now, so The 98 engine in a project car wouldn't be much different...
Old 02-02-2006, 12:52 PM
Im on a ranch!
speedybreesy's Avatar
yeah i was gonna point out the head/valve cover difference
GregWS6&z28's Avatar
kind of a hit or miss.... like some people have piston slap and others dont
Old 02-02-2006, 01:07 PM
my 98 has ran perfect with 93k miles of abuse. No piston slap, no oil problems, etc etc. Like it was said...kind of a hit and miss.
Old 02-02-2006, 01:31 PM
JDJP's Avatar
So would A 98 vette LS1, just wire and bold right up exactly like the original engine?
I know its not that simple, Im just trying to gage how difficult the work would be.
Old 02-02-2006, 03:00 PM
Ditmeion's Avatar
The 98s aren't as bad as some people let on...
True, 97 & 98 lS1 have the perimter bolt heads/valve covers
98s have an actual functional temp gauge, unlike the rest of the years.
Yes, 98s oil pumps are prone to failure, but most people replace them anyways while doing a cam swap.
I don't think piston slap was an issue with the 98, it started in 99
The 98s wiring to the PCM is different than the later years.(that's why it is difficult to find programmers for 98s)
With nitrous, I've hit over 500 HP on my 98, without any issues (stock bottom end)
I love my 98, of course I've already changed the oil pump & have gone with LS6 heads (center bolt valve covers), but it ran great even before those mods.
Old 02-02-2006, 04:25 PM
12secSS's Avatar
I agree, the 1998 engines are not as bad as proclaimed here. Hell Jen went 10.60s at 127 mph on her stock short block and into the 9s at 137 mph with a little 135 shot. The engine is still fine.
Old 02-02-2006, 04:40 PM
ChaseSS's Avatar
to correct people before all LS1's in 2001 and newer came with LS6 intakes... not just Zo6's but corvettes, fbodies all had LS6 intakes from 2001 to present
Old 02-03-2006, 01:19 PM
Muerte_X's Avatar
Uh, don't swap it, not unless you need a new motor.
I know i've posted this before, n00bs need to read the stickies.
There's some very minor differences, but in the end, they make the same power.
You said it to begin with, an LS1 is an LS1
Old 02-03-2006, 01:31 PM
'Trust''s Avatar
Weren't all the oil pumps the same through 00'? That failure only happens during low miles, not upwards of 40k on 97-00. Perimeter bolts suck yea, but an extra $100 on valve covers on top of new heads isnt a big deal. Owning a 98 you seem to research and weed out stuff people say thats false. My "bad 98 pump" was still working when i did the cam swap at 110k.
Old 02-03-2006, 02:28 PM
Luna's Avatar
I am gettin kind of sick of all this BS about 98s being so bad, my 98 doesnt burn oil, my friends 99 does, my 98 doesnt have piston slap, my friends 99 does, I get good oil pressure there is nothing wrong with my oil pump, and like someone else said my temperature gauge works, my buddies 99s doesnt. My 98 runs better than when I bought it and she just turned 87k today
Old 02-03-2006, 02:43 PM
jswelburn's Avatar
I second that. No piston slap on my car, good oil pressure (though not as high as the later models). Does burning oil and piston slap have much to do with the 98 oil pump? I doubt it. But it sure as hell says they're fine compared to later years.
This is just another internet rumor which has caught so much momentum that everyone believes it.
Old 02-03-2006, 03:03 PM
JDJP's Avatar
I think its a general "myth" which can sometimes be true. Ive always heard "never buy the first year any car was redisigned" Because all the bugs have yet to be worked out.
But its not like the engine isn't extensivley tested, and I think you could give common problems for most year can't you?
Old 02-03-2006, 03:39 PM
Build #1's Avatar
I have a 2000 and whats so bad about piston slap. Its just that the pistons are cold. As the motor gets up to temp and the pistons grow, than its all over. This is not just an LS1 charactoristic. Its possible with anything running hypernectic pistons. Everyones not saying that 97-98 LS1's are bad, just that if you do a build up on one, change the oil pump to a LS6 like everyone does to all years of the LS1's.
Old 02-03-2006, 04:15 PM
Ditmeion's Avatar
The oil consumption issue was becuase of the PCV system....some have problems, some don't, not specific to the 98s by any means....most people install a catch can, or just go to an LS6 PCV system
I LOVE MY 98
