can't find source of smell(mildew)
hey, i let the camaro (with t-tops) sit for about 3-4 weeks without being aired out. i opened up the door and was overwhelmed by a mildew smell. i had the windshield replaced right before i left, but other than that, ive never had any problems. maybe it didnt seal right? i have personnely smelled every inch of cloth in the car and cant find any trace of mildew smell, yet the car continues to smell. i have used the carpet cleaners, the baking powder, and i just used a can of ionizer. just wondering if anyone else has had this problem or anyone have a solution?
thanks
josh
thanks
josh
LS1Tech Administrator
Received 1,493 Likes
Never had that issue, but my guess is that the smell must be due to water/mositure intrusion somewhere.
My Camaro sits a lot. I like to keep the interior smelling new, so what I use is a product called Damp-Rid. It comes in a plastic tub that fits perfectly in the center console cup holder of a 4th gen. I buy it at Home Depot. It absorbes moisture in the cabin and traps it. It actually shocks me just how much water it pulls from the air, works great and always smells fresh inside.
You only need to buy the whole tub once, after that you can get refills.
Well, if you just had the windshield replaced (and there are no other obvious factors), I would start by going to the glass shop first. If they didn't seal it properly that thing will leak, and never dry if it gets into the insulation in the carpet.
They might be buying you new carpeting.
If they start to deny and argue don't back down, but be sure to argue respectfully and don't raise your voice, you have the upper hand right now. If they still don't agree to work with you, pay for a second opinion from another glass shop, You might even want to look for some forums (here or otherwise) that are windshield specific.
sounds like a plan, the windshield is the only thing i can imagine would leak, ive never had any problems with the doors or t-tops.
thanks
josh
thanks
josh
i have been airing mine out i nthe garage for the past week, and no cleaning product has been able to get it out, im going to try that damp-rid stuff, hopefully it works!
Originally Posted by josh1107
glass doctor is coming to look at it tomorrow, really nice company, hopefully they find the leak.
thanks for the help
josh
thanks for the help
josh
Jason
However, keep in mind that Damp-Rid was not designed to remove odors from water damaged fabric. It’s more for preventative maintenance; to keep moisture from causing this odor in the first place in areas that are enclosed or prone to dampness. If you already have a serious odor, I doubt this stuff will help you any in the short term. Of course it's worth a try though as the stuff is pretty cheap. But I'd expect that you will need to find the damaged portion of your interior and clean or replace it.
But going into the future, if your car stays closed up for long periods of time, the Damp-Rid will keep it smelling fresh.
i used an oust on-off air freshner, and a can of lysol professional strength midlew remover can, smells strongly of air freshenerm but not mildew, hopefully it'll stay away!
The Home Depot usually keeps that stuff either in the paint section or the adhesive/caulking section. Every Home Depot I've been to has it, so it's there somewhere.
glass doctor couldnt find a leak in the windshield, still looking for leak....
there was actually a service bulletin about the A/C system causing a moldy/mildew smell if let sit for a while in humid climates...i can try and find the info if you pm me
