The Order of Mods
The Order of Mods
I just bought a bone stock 98 ss m6 with 34k. It has SLP dual/dual catback. Im looking for opinions on what order to do mods with the goal of eventually getting to cam/heads. The dual/dual exhaust is too quiet, but Im not ready to give up on it yet. So Im thinking it might go something like this:
Lid/filter
Lt's/ory w/cats on SLP dual/dual
Intake
Suspension/clutch/wheels-tires
Cam/heads(possibly true-duals at this point)
12 bolt
The car will never be more than a weekend driver, but I still want it to be streetable. So I guess the ultimate goal is about 400rwh with bolt-ons, stock bottom end and no juice.
What do you guys think???
Lid/filter
Intake
12 bolt
This is what i'll be doing. 95% of this will be done over winter along with other items i'm forgetting.
1. New catback w/ LT's and ory
2. whisper lid
3. de screened mass air
4. LCA's/STB/SUBFRAME CONNECTORS/PANHARD BAR/ X member mounted T.A.
5. Pro stars w/drag radials
6. TNT F2 nitrous kit
7. upgrade fuel system
8. stand alone nitrous fuel system
9. upgrade the rear w/new axles and a better posi
10. HAL coil overs
11. Throttle body
I'm sure i'm forgetting something
2. whisper lid
10. HAL coil overs
11. Throttle body
So I guess the ultimate goal is about 400rwh with bolt-ons and stock internals and no juice.
1. Flowmaster catback
2. K and N w/ whisper lid
4. Suspension over winter
5. Pro stars w/ drag radials
6. NOS nitrous kit w/dual fogger nozzles with Rpm activation installed
I'm sure i'm forgetting what else i'll be doing
I would skip the flowmaster, on an ls1 it will flow badly
your abn m6 atleast beef up the 10 bolt 1st or do a 12 bolt as 1st mod......
rear of some sort
good clutch
suspension
sticky tires
then bolt ons
all that power is useless if you cant put it to the ground.....the ls1 has the powwer in stock form to run 12s......
rear of some sort
good clutch
suspension
sticky tires
then bolt ons
rear of some sort
good clutch
suspension
sticky tires
then bolt ons
rear of some sort
good clutch
suspension
sticky tires
then bolt ons
Originally Posted by slow1999blackz28
It's a good list but doesn't it include H/C thats not quite stock internals haha. Good luck on gettin there though.
Well, stock bottom end anyway.
Thanks for the replies guys. I figured some of you would tell me to work on putting it to the ground first. I think I will re-think my order a bit.
Trust me as soon as you do LT's and heads your duals will be LOUD! and your duals will net more power, dont even think about changing to a y and catback you'll regret it.
Doug
Doug
Lid/filter
Intake
12 bolt
The car will never be more than a weekend driver, but I still want it to be streetable. So I guess the ultimate goal is about 400rwh with bolt-ons and stock internals and no juice.
Lid/filter
Intake
12 bolt
I don't remember why I put that up considering it already had it when I picked it up. Hopefully over winter, I'll be installing a borla setup. Heard an Ls1 with it, man did it sound goooooooood.
Dont forget a new transmission guys lol the stock 4l60e was dieing out on me at around 50k miles and my buddy with a m6 he bent a tooth :/. If you got a 4l60e I would build it up a bit before going into the h/c situation. Shift kits are fun!
I think that trying to put it to the ground would be the best way first,
1. cut out
2. subframe connectors
3. rear end
4. heads/ cam (preferrably together)
5. TB
and more if you feel like it.
1. cut out
3. rear end
5. TB
