Help me with mods
Help me with mods
So far i have a lid and catback on my car... Planning to install 4.10's (but will have to decide on that later. A big problem for me is that I live in CA, so i will need some Smog Friendly mods, so no cam, long tube headers for me, etc...
Besides those mods which ones would you recommend, that are smog friendly??
I really want to bring my car up to at least 350 RWHP
thanx
thanx
thanx
thanx
What part of CA do your live? I lived in the Riverside area for about a year....and honestly....its absolutely impossiable to mod your car and obey their textbook smog rules at the same time.
They are so rediculas when it comes to referee's/smog etc etc. I feel bad for ya
Here are the mods I can think of off the top of my head that they would have too really know LS1's to notice if they ever popped your hood.
HP mods
-Underdrive pulley
-SSRA(since its under your car dont know if they would bother or not)
-tune/flashscan (EFI/HP tuners etc)
-Ported Throttle Body
-Ported maf
Might look into some LCA's, SFC's,Panhard bar, TQ arm etc etc....will help out tons in the suspension/chasis area.
I don't think you'll be at the 350ish whp area with more mods that arn't smog friendly....but you are VERY limited to mods that won't attract attention. People just dont understand how bad California really is about this smog stuff unless they have actually lived there.
I know you said no cams but one of the easiest ways to get there imo..would be too put a VERY mild "sleeper cam" in IE a TR CheatR cam etc..and vist a "local" shop to pass your visual and smog
or put a Nitrous Outlet money maker kit in there and hide the bottle in the spare tire area.
Once again...I feel bad for ya....hope this helps.
thanx man, you really helped a lot. I live a few miles from Los Angeles, unfortunately. Does throttle body add any power? Or how about a fast 90mm intake manifold????
I think your best bet for now would be too keep your LS6 intake mani and port your stock TB for a few extra ponies.
You car has a LS6 intake mani on it right now which flows pretty well for your power level.....Yes...a Fast 90/90 setup with a intake mani and TB would help you out ....but a CHP might cite you for it on an inspection from the sheer fact of the labels on it You never know with them....
Thanx! by the way, that manifold is smog friendly, right???
if youre worried about staying smog legal (which isnt any fun) id say port ur TB, get a tune and then focus on getting some suspension for your car to plant the power since youre gonna have 410s. adding power in CA and passing smog is almost impossible. you could look into upgrading your cam to a ls6 or a GM hot cam kit. those still pass smog with good tuning. or call a performance shop and see about some custom grind cams/cheater cams etc.
personally i would say **** CA emissions and just mod your car and just try not to get caught!
Thanx, i will look into those cams (how much would they add btw?), and not passing smog is not a possibility for me
Almost positive with lid/catback/UD/ported tb/cam you would be at your goal as long as your tune was done right.
Any 90 or 92 mm tb will not fit your LS6 Intake mani, just get your stock one ported. Start off smaller, maybe get the underdrive pulley(SLP, ASP, powerbond), get the TB ported, and then look into cams.
98-02 LS1 ASP Racing 25% Underdrive Crank/Alternator Pulleys that add around 10 hp
and also 98-02 LS1 March Performance Dampener Pulley
I mainly shop in Ws6 store- great website, already purchased couple mods from there. And again, sorry for the noob question, but those cant both be installed right? Its either or?
P.S. Tune will definitely be done once i do all these mods, and only after that i will look into new rims and maybe lower the car 2 inches, put some street tires, but that will be another story... i know nothing about suspension yet
One suggestion: DON'T waste money on gears for the 10 bolt. Get a 12 bolt or 9" instead. Can't afford it? Good, Good, that means you have something to save for. Guys with limited budgets have all the more reason to only spend money once. Personal experiance: Broke the 10 bolt with lts/TDs/Lid. Upgraded to 9", and was by far the best mod i did.
Thanx for the advice though, another thing for me to look into
This is what you do. You go ahead and get a set of LT headers, the FAST 90mm intake/TB. Get a custom Y-pipe made for you, but make sure that they dont weld it to your catback. Then when smog time comes around, you put on your stock intake/exhaust. Pass the sniff, and you are good to go. You might want to look into getting MSD Wires and coils and iridium plugs. Thats what I would do if I was worried about passing the smog.
But then again I have my car registered in Michigan, so I dont have to worry about smog...also if you go that route, remove your EGR and air pump. It will clean things up. Keep it in your garage until smog time comes around and put it back on.
pulley, ported MAF ends, ported and polished t/b, a cold air kit of some sort, the SLP y-pipe to replace the flat piece and you could go shorty headers to stay legal, and a tune
By now, thats what i am thinking: 410's, FTRA, High flow MAF, Pulleys, strut brace bar, possibly a ported tb? and to top it all off a nice tune
And then, wheels and suspension mods...
