a4 2 m6
Old 05-17-2008, 01:40 AM
MrRamAir's Avatar
Default a4 2 m6
i have the a4 and i want to change it to stick.
how do i go about doing this?
where do they sell m6's?
how much is this going 2 cost me?
no i cant do the work myself.
thanks
Old 05-17-2008, 02:37 AM
Bmx4Rizzo's Avatar
thanks
With those two lines in bold= one word answer-ALOT. A stall is your friend dont be scared, auto are faster if done right. Good luck
Old 05-17-2008, 07:02 AM
KrisXpc's Avatar
Some people will trade you straight up for your A4 setup if your lucky..
Its not as pricey as someone would think.. t56's can be bought for under 1000.. Maybe 1500 for a complete swap..
Your a4 can be sold for 800 - 900 give or take..Depending on if it comes with a stall and how many miles are on it.
Look under the Manual section of the forums, it has swap info.. The complete swap shouldnt cost you more than $3000 through a shop..
If you have a 98, your better off having the PCM changed over to a 99+ (Have a shop do this)
Old 05-17-2008, 07:35 AM
melchoir's Avatar
It's generally pretty difficult to find a good condition T56 that's not local for under $1k. I would estimate $1500 for the tranny alone. You will want new hydralics, and probably a new clutch assembly+flywheel as well. (or get used flywheel and resurface it). Part cost can range wildly, but if you're buying everything I'd estimate around $2500 for true part cost.
Most shops will do the install for around $1000 for labor. As for having a 98, there's no reason to not keep the same PCM. Regardless of PCM year, it will require having it's tune switched over to an M6 tune.
I just completed this swap on my 98. Check the manual transmission section.
Old 05-17-2008, 07:43 AM
MrRamAir's Avatar
thanks 4 the info !
Old 05-18-2008, 11:21 PM
chvycmaroz28's Avatar
keep the a4 man...dont get me wrong a 6spd is fun but a high stall with a shift kit churpin the tires in 2nd is just as much fun
Old 05-18-2008, 11:39 PM
LS1Silverado05's Avatar
Been there done that, went back to A4. My advice, stick to the A4. Why exactly do you want the M6? Unless you are building a road course car, I would stick with a stalled auto. I wish I never wasted all the time and $$ on the M6 swap....I am happy to be back to A4.
To answer your question... Maybe $2000 in swap parts IF you are lucky and find good deals. Maybe another $1000+ for labor... Do alot of research man, its really not THAT bad of a swap to do yourself... If you have some mechanical ability and can afford the down time, you can do it.
Old 05-18-2008, 11:47 PM
9000th01ss's Avatar
You should do the rear gears too. A4's come with 3.23's and M6's come with 3.42's.
An M6 with 3.23's sucks. I did a swap in my SS and put in 3.73's. The whole swap, trans, rear and all cost around $2600 doing all the work myself. Using a $1600 M6 with 34,000 miles, about the same that was on the car at the time.
And before anyone calls me stupid look at my sig.
Old 05-19-2008, 12:41 AM
Why would anyone call you stupid?...
Old 05-19-2008, 12:57 AM
Kingc8r's Avatar
I miss driving a M6 vehicle from time to time, but I know once I get my stall I won't miss it nearly as much. Tell us why you want to make the switch, as stated before we may be able to sway your mind either way......
Old 05-19-2008, 01:23 AM
Black99T\A's Avatar
I just got done doing the swap, cost me a little over $2000 for everything doing the work myself, if you have someone do it for you, you'd better tack on about another $1000 for labor
Old 05-19-2008, 12:47 PM
9000th01ss's Avatar
Because there are several threads 15+ pages were people ask about doing this swap and the pros and cons, etc. The arguement goes back and fourth forever.
I don't have to worry about being part of any of that because I have two almost identical cars, one with each trans type.
