colder plugs?
Old 10-24-2008, 10:59 AM
z28rob18's Avatar
Default colder plugs?
ok everyone says to run the tr6's but y do u need the colder plugs wit nitrous?
Old 10-24-2008, 12:00 PM
Sigforty's Avatar
To avoid detonation, and keep from melting the plugs.
Old 10-24-2008, 12:07 PM
Nick@HSW's Avatar
Its not only due to the higher cylinder temps associated with nitrous use, but also the rate at which the temperatures rise. So next question obviously should be, well why higher temps with nitrous, right? Well ultimately temperature is in direct relation with pressure in this system. As you're adding pressure, you're adding heat and are now bound to the laws of thermodynamics. So the only way to pull the heat out of the cylinder is with the spark plug.
Nick
Old 10-24-2008, 12:15 PM
Ksths2's Avatar
TR6'S are sweet and cheap
Old 10-24-2008, 01:01 PM
1969mach1's Avatar
Nick
what he said! ^^^
Old 10-24-2008, 04:25 PM
allmotor's Avatar
I got 16 TR7's for 40$ from summit
Old 10-24-2008, 09:02 PM
Nick@HSW's Avatar
Originally Posted by 1969mach1
what he said! ^^^
That's just knocking on the door...I could also discuss the chemical side of things involving heat.
Nick
Old 10-24-2008, 09:03 PM
waterbug1999's Avatar
run TR-7s here.
