biggest shot on a single nozzle?
Old 10-28-2008, 12:49 PM
z28rob18's Avatar
Default biggest shot on a single nozzle?
wats the biggest size shot i could spray on a single nozzle wet kit can it do 200 or would i need a plate?
Old 10-28-2008, 02:51 PM
Nick@HSW's Avatar
Depends on the kit you have. I would call the manufacturer and see what they rate it to. People have done 200 through a single nozzle, but I personally wouldn't.
Nick
Old 10-28-2008, 03:19 PM
z28rob18's Avatar
Nick
y wouldnt u do it?
Old 10-28-2008, 03:20 PM
5_02ls1's Avatar
there has been people who have done a 250 thru the shark nozzle...now wether they got the full 250 who knows
Old 10-28-2008, 03:59 PM
Nick@HSW's Avatar
Originally Posted by z28rob18
y wouldnt u do it?
Distribution. You'll pick up better distribution with a plate kit versus a single nozzle.
Its just my opinion as I'm sure others will disagree with it. My only advice with nitrous is to always err on the side of caution.
Nick
Old 10-28-2008, 04:52 PM
HotRod68Camaro's Avatar
Nick
I definetetly agree with you there. I am going to be spraying a 150 through mine, only b/c i already had the nozzle on the car when i bought it. In the next couple of months though i will be going to a plate kit.
Old 10-28-2008, 09:50 PM
Orr89rocz's Avatar
spraying 150 thru a single HSW nozzle kit. Seems strong, picked up 8 tenths and 9 mph from mid 11's to almost mid 10's now.
i'll be dynoing it to see how close it is.
What about dual nozzles, you can get better distribution with a 200 shot with dual nozzles correct? each spraying 100 i pressume?
Old 10-28-2008, 09:53 PM
Frans96SS's Avatar
I had over a 200 with a single nozzle. I think the -3 lines to the nozzle become a restriction at that point. I personally would do a twin nozzle set up. Not much more money and will handle alot more power.
Old 10-29-2008, 09:42 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
You are correct that the -3 lines start to become a restiction above 150 HP....if you upgrade to a -4 line w/a -3 nut on one end you can outflow the nozzle.
As far as what is the max you can spray on a single nozzle, that will be determined by the nozzle.
NOS nozzles 150HP
NX Piranha, Nitrous Outelt 1/16, and Brand X 1/16 200HP
NX Shark & Nitrous Outlet 1/8 250HP
NX SHO 400HP
Now would I run a 400HP shot through a single nozzle.....not unless the rules of the class I was running made me
Old 10-29-2008, 05:09 PM
Orr89rocz's Avatar
when you say -3 an line is a restriction above a 150 shot, is that a 150 shot rated at wheels. Most kits are whp rated correct? Because my 150 shot is so technically thats a 175 shot and i was concerned i wasnt getting the most out of the shot size and wondered why
Old 10-29-2008, 05:14 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
175 will likely be OK unless you have a very long line or tight bends in it.
I suggest replacing the nitrous solenoid to nozzle line anytime you go above the 150 shot jetting. (Approx a .062 jet) Just in case
Old 10-29-2008, 07:52 PM
Orr89rocz's Avatar
thats what i'm using, .062 jet. That suppose to be 150whp/ 175hp on motor. Main Line is from the trunk to the front, straight but long. Its a 4 an line. From the solenoid its a 3an line to the nozzle but its only a foot long piece of line and its straight to the nozzle.
I'd have to find out if i can get a 4an line to the nozzle with a 3an nut on the end
Old 10-31-2008, 09:15 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
we can make the line for you if needed....but at your current jetting the 3AN is fine
Quick Reply: biggest shot on a single nozzle?
