WIll my stock bottom end take any n20 with the mods i already have
Hey guys,,,I have a 99 ss camaro 6spd... I was wanting to put some spray on my car and was wondering if or what it could handle if any?? These are the mods I already have... My internals are stock but heres my list of stuff i have done....
Performance
241# LS1 Stage II Ported Heads w/ stock valves
Comp Cams 244/248 .598/.598 115
Comp Cams Titanium retainers
Comp Cams 918 Springs
Comp Cams 7.350 pushrods
FAST LSX 78mm Intake
LS6 Ported oil pump
Rollermaster double roller timing chain
2.5" Off Road X pipe w/ Flo Pro Twister mufflers and optional cutouts before the mufflers.
FLP long tubes
Whisper Lid
Smooth Bellow
Home Ported Throttle Body
!AIR (have most of the emissions equipment in a box as well)
!EGR
NGK TR55's
MSD Super Conductorslll
Please any info would help... I would like to go crazy with like a 150 shot or something but i just dont know if the stock block will take it or not... As of right now im putting down 444whp and 401pds of torque... Thanks
Performance
LS6 Ported oil pump
FLP long tubes
Whisper Lid
Smooth Bellow
!EGR
NGK TR55's
you will be fine with a 150 if you have the fuel to support it.
my c5 is similarly modded and makes the same na numbers your making. i am spraying nitro daves wet kit with a cell (110).
heres my dyno sheet.
https://ls1tech.com/forums/nitrous-oxide/1012991-nitro-daves-wet-plate-kit-dyno-numbers.html
just like dawiz said, 150 will be fine as long as your fuel system can keep up and you have a good tune. My stock bottom end car puts down 496 rwhp and gets hit with a 200 shot. we have another customer with a similar setup like you, 445 rwhp and hes been spraying 275 for two years. Its all in the tune
