nitrous fill question
Old 11-22-2008, 01:02 AM
Ruckus46Gt's Avatar
Default nitrous fill question
Is there any benefit to filling a bottle from empty then from a bottle that has like 4lbs left?
Old 11-22-2008, 02:28 AM
b00sted's Avatar
Not that I know of. It may be harder to do without a pump.
Whenever I fill a bottle that has 1-2 lbs. left in it, I just empty it. That chills the bottle and speeds up the fill time.
I'm not sure if it really matters.
Old 11-22-2008, 02:47 AM
Ruckus46Gt's Avatar
I dont like the hit after 4lbs and most places it seems like only want to fill empty bottles. I'd rather not waste the 4lbs everytime on both bottles
Old 11-22-2008, 09:32 AM
02blackbeauty19's Avatar
If you have a pump it doesnt matter. When I fill bottles, its just as easy to do it both ways
Old 11-22-2008, 10:17 AM
myfast70's Avatar
I thought you were getting a NANO setup? NANO has a complete 15# system on Ebay for $339
Old 11-22-2008, 01:07 PM
Nick@HSW's Avatar
I would recommend at least purging the bottle prior to filling it. No need to empty it.
Nick
Old 11-22-2008, 01:30 PM
99ccz28's Avatar
I use the freeze and fill method and have no problem. Takes about two times though to get it full.
Old 11-22-2008, 06:41 PM
Ruckus46Gt's Avatar
I am but waiting till after xmas have to buy another bottle since my hsw one will not work with the nano so that will be the cars christmas gift. I was going to get it a fuel pump but figured this would be better
Old 11-22-2008, 07:03 PM
jmill96Z's Avatar
Just toss the bottle in the freezer, and it'll fill great.
Old 11-22-2008, 09:39 PM
BobDoLe's Avatar
where'd you get this information?
my nano kit works flawlessly with my hsw bottle.
i contacted harris speed works through their website back in may before i bought the nano kit and asked:
I have the HSW sudden impact dry kit with the 10lb bottle and I was wondering if a NANO kit will work with the valve that comes with the
HSW supplied bottle?
their email response:
from Customer Service @ Harris Speed Works <customer-service@harrisspeedworks.com>
reply-to customer-service@harrisspeedworks.com
date Thu, May 22, 2008 at 6:41 PM
subject Re: Harris Speed Works: User filled in Contact Us Form!
May 22
Yes it will.
so who is spreading misinformation that it won't? have they changed the bottles in the last few months or something?
Old 11-22-2008, 11:51 PM
Ruckus46Gt's Avatar
last time i asked the question I was told it wouldnt that the valve does not have that hole in the inside that is needed. Maybe someone from HSW can chime in...I got my kit when they were offered dirt cheap last jan
Old 11-23-2008, 10:17 AM
myfast70's Avatar
How many ports do you have on the sides of your bottle? Is your bottle empty now? If you've got a gauge on the side of the bottle that contantly reads pressure wether the valve is open or not then you should be able to the NANO without any problems.
Old 11-23-2008, 11:18 AM
Nick@HSW's Avatar
Yes the valves we use will allow the use of a system like that. The only thing you need to know is the through hole diameter. I can double check them dim for you on monday if need be. You would just have to either ditch the gauge or move it with an inline adapter.
Nick
Old 11-23-2008, 02:12 PM
Ruckus46Gt's Avatar
side port where the guage is has to have a vent into the bottle. When I asked last time was told that hsw's guage port wasnt a push set up
Old 11-24-2008, 01:59 AM
Ruckus46Gt's Avatar
found the post I was looking for finally
Originally Posted by Ray@Nitrous Outlet
I "think" it will....you might want to verify with HSW to make sure tho.
You need to know if their pressure port accesses the siphon tube or the pressure above the liquid.
The base of the valve should have a small hole that lines up with the pressure port if it compatible.
this is a NX 45* valve...it has 2 pressure ports...as you can see there is only one port on the base, so only one of the side ports can be used with the NANO
