direct port, fogger nozzle placement
Old 12-27-2008, 04:20 AM
stephen p's Avatar
Default direct port, fogger nozzle placement
i was wondering, it is possible to put the fogger nozzles under the intake on a v8? has any one tried this before?
Old 12-27-2008, 07:18 AM
Mike@HSW's Avatar
It depends on the intake manifold you have. most of the time its really not a good idea, a jet change would require you to remove the entire intake
Old 12-27-2008, 08:54 AM
z-ya's Avatar
I've done it before to hide things .
Old 12-27-2008, 07:20 PM
stephen p's Avatar
well, i'd probably have 2 kits, one plate, one direct port chances are i would leave the jetting alone on the direct port. and i realise it varies from engine to engine, im looking at doing it on a pontiac 400. as i said, im sure the clearence in the lifter valley varies..
Old 12-28-2008, 03:46 PM
BAKED's Avatar
Just place them wherever you have room and try to make them uniform. The main thing to make sure of is the angle you put them at. You want to place them so that they are spraying as close as possible to the intake valve.
What kind of nozzles do you have? straight shooters or 90* ?
Old 12-28-2008, 07:15 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
Carb intakes old school SBC or BBC yes very doable, but a huge pain in the backside. Newer mode GMl stuff there just in not room under the intakes.
Old 12-29-2008, 10:04 AM
Nick@HSW's Avatar
There is slightly more room on them with the valley cover. I would just verify you have enough rise on the runners to clear the nozzles. Is there a reason why you want it under the intake? The water crossover will block some of the view, but it won't really be that hidden.
Nick
Old 12-30-2008, 10:38 AM
N2OMIKE's Avatar
Something like this LT1?
Old 12-30-2008, 11:47 AM
Chris@NitroDaves
Guest
Posts: n/a
Another example of an Under Intake setup
-Chris
Quick Reply: direct port, fogger nozzle placement
