Will 75 wet shot be fine!
All my mods are listed in my signature i have around 380 horses and going to be spraying a 75 wet shot on a TNT power ring kit. And what to know what you guys would change or do before spraying. Oh and the clutch is stock and that will be around 455 horses how will clutch and injectors and pump hold up.
Guest
Posts: n/a
I assume with the mods that you have you have had the car tuned. Do you know what the timing is set at? You will definitely need to get some TR6 plugs to accommodate the nitrous. Also with the power that you are making now you will be right on the limits of the stock pump. Typically I've seen the stock pump hold around the 450 to 480rwhp, but keep in mind that every car reacts different and what works for one might not work for you.
-Chris
-Chris
