Help with power ring!!
Old Jan 3, 2009 | 08:02 PM
IndigoSS's Avatar
Default Help with power ring!!
I have a TNT kit and i can not get the power ring on with the O-Ring in the ring if i take the O-Ring out it will go on better has anyone had this problem? I just want to make sure it has a good seal. Is it ok if i leave the O-ring out? Thanks for any info.
Old Jan 3, 2009 | 08:53 PM
Cam72aro's Avatar
I would say no to leaving the o-ring out. It could cause a leak downstream of the maf and throw off airflow readings. I would use the o-ring and throw some wd40 on it and slide it in. I also think that the power ring uses an allen set screw, you might have to loosen it a bit. Let us know what you come up with.
Old Jan 3, 2009 | 09:59 PM
IndigoSS's Avatar
yeah i loosened it all the way but can not get the damn thing to go on with the O-ring and even with the oring off it wont go on all the way and my Tb is 78mm.
Old Jan 4, 2009 | 11:53 AM
sleeperstyle's Avatar
if you search- well everybody has a problem getting them on. mine took a while. use a little grease on the o-ring, and a piece of wood and a BFH. carefully beat the ******* thing on there :devil.
and yeah you need the o-ring.
it'll all be worth it when you spray it
Old Jan 4, 2009 | 11:54 AM
IndigoSS's Avatar
ok well im bout to go beat it then. haha
Old Jan 4, 2009 | 02:38 PM
dudeman's Avatar
i had the same problem. i didnt have an o-ring. i took a piece of vacuum hose and sliced down the middle. it seems to be working fine. i had to take a small screw driver and poke at it until it went on all the way.
Old Jan 5, 2009 | 02:51 PM
IndigoSS's Avatar
i put my power ring in the oven for an hour or so and heated it up then took it out their and it went right on with a few hits with a dead blow.
Old Jan 9, 2009 | 01:13 PM
NastyC6's Avatar
yep, i had to beat mine on. i called tnt when i got the kit 4 years ago, and thats what they reccommened too. haha
Old Jan 15, 2009 | 02:09 AM
slowpoke96z28's Avatar
had the same problem. that was the biggest bitch of the whole install. i talked to some people at TNT myself, lol.
Old Jan 15, 2009 | 02:15 AM
https://ls1tech.com/forums/nitrous-o...-tnt-ring.html
here is my thread from a couple years ago. you aren't alone in this, lol
Old Jan 15, 2009 | 07:58 AM
JoeyGC5's Avatar
Filing the retaining ring on the throttle body lets the ring slide right on with a good interference fit also.
