Hesitation question!
Old 02-18-2009, 10:27 PM
domestic disturbance's Avatar
Default Hesitation question!
well guys i just got my kit all redone today! Put a 125 shot wet direct port kit... the kit that has the Foggers that goes under the injectors... So question is I went to spray it, and at full WOT for a second or so it falls on its face then picks back up and pulls smoothly... question is what do you think it could be... Im trying to get it all worked out bc im taking my car around 3 or so hours away to get it tuned, and i dont want to get down there and not be able to tune it also if its a fuel problem or something, can you work it out by tuning it???
Old 02-18-2009, 10:31 PM
crmartin99's Avatar
how many times did you go WOT?
If only once, it could be as simple as air in the lines, then you felt the nitrous hit.
If not, as some one else
Old 02-18-2009, 11:16 PM
hmm wot... i did it twice id say... 1st and in 2nd... dont really want to run it to hard until i get it tuned... but i kind of figured it wasnt air in the lines if i purged the nitrous... and then i hit the nitrous in first, and if there was air it should have been out bu the time i hit second... but i dunno.... it could be lol....
Old 02-19-2009, 09:48 AM
crmartin99's Avatar
You're right, It should have hit nearly instantly, but hey sometimes it's the simple things that keep us tied up the longest
Maybe someone else could chime in.
Old 02-19-2009, 10:47 AM
Nick@HSW's Avatar
What kit is it? Were you doing any logging during the runs?
Nick
Old 02-19-2009, 02:28 PM
what i have is NOS Fogger's (the ones that go under the injectors) And nx solenoids... and the .020, and .010 solenoid jets...
Old 02-22-2009, 11:55 AM
BACK UP TTT thanks
Old 02-22-2009, 03:28 PM
I got the car tuned, car is still stumbling at wot... then hitting hard... Deal is If i hit it at 3500 Wot 2nd gear it stumbles and then hits hard, then when i hit 3rd its live and hits hard.... no stumble, but if i give it a few minutes and do it again same thing happens as stated above! I dont really know were to start, any help would be helpful!
Old 02-22-2009, 04:09 PM
MYSTIC-1SC's Avatar
i assume you have checked all the lines for leaks, and your bottle is up to pressure when you sprayed.
Old 02-22-2009, 05:07 PM
xpndbl3's Avatar
do you purge before spraying it? i'd purge it and see if it goes away. Sounds like it's hitting fuel first and nitrous is coming on afterwards. A good wideband would show this as well.
Old 02-22-2009, 07:45 PM
yah i purge it but dont sit there and purge the hell out of it lol.. maybey i need to purge it real good! But we had it hooked up to a wideband while tuning it and spraying it... it jumps a little lean when spraying it.... and levels out a little.... bottle psi was around 1000-1050
