Nitrous + 4.10 gears
I currently have MTI stage 2 heads with a C2 cam, VIG3600 and 4.10 gears and a set of 26" slicks. Would it be possible to spray the car with a 100-150 shot? I would be adding a fuel pump, but I'm concerned about both the converter and the gears being too high. Any advice would be apreciated.
Thanks,
Mark
Thanks,
Mark
Thanks,
Mark
Thanks,
Mark
I assume with the heads and cam you are probably red lining around 6800rpm or there abouts. 4.11's at 1:1 gear ratio with a 28" tire you can trap about 132mph at 6500rpm, and at 6750 about 137mph. If you plan on more than a 140mph trap speed you may want to consider a different gear ratio. Those MPH estimates are rough give or take 1 or 2 mph depending on the type of tire/slick you are using. If the tire has a lot of side wall centrifugal force will turn a 28" tire into a 29" tire.
Originally Posted by Nine Finger 02 Z28
I am not sure about your converter bt dependind on your MPH you may run out of gear on the 26's.
Lets see...
Car runs 119mph on the motor. Spraying a 100 shot should net 10mph (give or take). So say the car goes 130mph on the spray. I should cross the traps right around 6800-6900. My rev limiter is set at 7000rpm. So technically i COULD pull it off without changing my tire size or gear ratio correct?
yea, you could do it, i wouldnt count on 10 from a 100 shot, i would say 8 for sure. i dont think i would want to twist the motor that hard. maybe look into a set of 27 hoosier qtp's, thats what i ran last year, and worked good!
theres alot of factors that will go into play on that.
Restricted User
Don't forget about converter slipage. Your A/4 will slip a bit so you will be running higher revs and less mph as compaired to these M6 cars. Get 27's and you will be fine. I am going 28's with my new 4.11's and to aid in traction...
I ran N20 (150 shot) with a Moser 12 bolt/4.10's, but I used M/T ET Drags, 28"x9.5".
These actually measure 27.1" and do not rub anything, they "grow" .5 inches according to MT.
The shift light for 5th was coming on just as I went throught the traps, set at 6800rpm.
