how to Gap the plugs ?
Old 07-30-2009, 12:25 PM
PONTIAC SLP's Avatar
Default how to Gap the plugs ?
i have searched but no results and couldn't find anything .
Old 07-30-2009, 12:55 PM
Mike@HSW's Avatar
do you mean, what to gap the plugs at or physically how to gap them?
http://www.amazon.com/Lisle-67870-Sp.../dp/B000CODS8K
Old 07-30-2009, 10:40 PM
yak
yak's Avatar
Drop them
Old 07-30-2009, 11:07 PM
jmill96Z's Avatar
I usually use a feeler gauge. Or a piece of .032 safety wire if I'm in a pinch.
Old 08-01-2009, 04:45 PM
jc99ls1ss's Avatar
Autozone has the gap tools stacked up by the register.
Old 08-01-2009, 07:28 PM
can u please guys give me links for best tools
Old 08-02-2009, 08:01 AM
n2ocamaro's Avatar
So you own a 600+hp car and don't know how to gap plugs? Not knocking on you, just sounds odd!
Old 08-02-2009, 09:08 AM
6 & 8 Second Club
mrdragster1970's Avatar
Get an owners manual or chilton's manual. They usually have pictures.
Hoping this is a joke??
Old 08-02-2009, 03:48 PM
lol i'm running TR-6 plugs un-gapped and spraying 250HP.
Old 08-02-2009, 03:58 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Yea, this is gotta be a joke..
Old 08-02-2009, 08:39 PM
6 & 8 Second Club
How the hell did he get 1000 posts and can't change a plug??
Is there a cooking section somewhere??
Old 08-03-2009, 01:10 AM
I did't said i don't know how to change the plugs i meant what is the faster and the best tools that we can gap the plugs understood ?
Old 08-03-2009, 07:12 AM
6 & 8 Second Club
I understand, do you?? You said in your 1st post "How to gap plugs" nothing about our favorite tools!!
Then you said you run your plugs un-gapped, which would not fire!! If your 1st, 2nd, 3rd post ect are misunderstood.
Most of us are happy to try & help you out until we get it figured out what your asking.
This is one of the few sites that are not over run with know it all, want to be's that ruin every other thread.
I don't know everything, but I do have 4 hot rods and know a little about this or that.
Good luck.
Old 08-03-2009, 08:03 AM
6 & 8 Second Club
Plus you're in the wrong section, so we assumed you didn't know what you're doing??
Old 08-03-2009, 09:30 AM
Mike@HSW's Avatar
More importantly TR6 and 250 shot = VERY VERY BAD IDEA
Old 08-03-2009, 08:20 PM
how about NGK BR7EF with that amount of nitrous ? i'm planning to order them from yours.
Old 08-03-2009, 08:45 PM
6 & 8 Second Club
I run 10's on my 250 tune up. Not worth risking having too much heat in the hole.
My 2 cents, good luck.
Old 08-04-2009, 01:28 AM
Good luck.
yeah me also , The reason that i installed TR-6 because the other plugs are not available over here, most plugs are available here is TR6 and TR-55 and most shops sells them , good luck with your hot rods .
Old 08-04-2009, 11:42 AM
6 & 8 Second Club
As Mike said, a #6 plug is a bad idea. Most of us use a 7-8 for a HP engine. No way could I run a #6 plug.
I would rather wait until you get a #10 shipped over. I myself buy them 50 at a time.
I always have 3 plugs per hole ready to go so you don't waste time screwing around at the track. With a #6 plug,
you are running way to much heat through your engine. Either you've been real real lucky,
or you took out a ton of power to keep it together. Get some 10's & hang the heck on.
Old 08-04-2009, 12:10 PM
Mike@HSW's Avatar
Whats done to your motor if anything? stock compression? shot size alone does not determine plug choice. assuming stock compression id just run an 8, 7 might be ok, but there's no reason not to run an 8 either.
