What is the max for an LS1?
Old 09-02-2009, 03:01 PM
swomp rat's Avatar
Default What is the max for an LS1?
I am putting together a 427ci. LS1 with Dragonslayer crank, Oliver rods, and Diamond forged pistons. This motor is going to be running 12.25-1 compression. I was just wondering what the max shot you can run on this setup would be. I know this is a matter of opinion on what is safe and what is not but I'm just looking for some feedback on this subject.
Old 09-02-2009, 03:08 PM
tim99ws6's Avatar
There's tons of variables on what you can hit that with. dry/wet, single/multiple stages, DP/nozzle/plate, is the entire motor ARP studded? what bearings? Heads? Cam? What Gas? Progressive controller or straight hit?
Old 09-02-2009, 06:02 PM
BAKED's Avatar
The main thing that will limit you will be how good your tuner is..... You would be surprised at what it would hold with a pro reading plugs and doing all the tuning.
Personally, I wouldn't hesitate to hit it with 500+ if it were staged.
Like Tim99 said, WAY too many variables.....
Old 09-02-2009, 09:56 PM
swomp rat's Avatar
It will be ARP fully studded, with dart 250cc heads, a wet two stage kit through a TNT two stage power ring, it will be a custom cam, on 110 race fuel, more than likely a straight hit system. Sorry for not filling in those blanks before. I am more than likely going to have a good shop in Grand Rapids Michigan do the tuning.
Old 09-03-2009, 08:15 AM
ATVracr's Avatar
Stock style intake with a power ring ... 250 would be my max.
Get a carb style intake and a real plate and 5-600 max.
Old 09-03-2009, 11:13 AM
swomp rat's Avatar
What about if I go with a stock style intake and run a one stage wet in the power ring and do the second kit as a direct port? Or just go with a two stage direct port kit?
Old 09-03-2009, 11:27 AM
ATVracr's Avatar
Alot of people do that with great success.
just limit the ring to 200 or so and spray the hell out of the DP.
Old 09-03-2009, 12:05 PM
krazy4's Avatar
Yeah, spraying through the stock intake I would keep the jetting around 200hp.
With a direct port setup or a legit carb plate, you could hit that thing with quite a bit.
All depends on the tune though.
Old 09-03-2009, 03:33 PM
swomp rat's Avatar
Thanks for the advice guys... I will keep you up to date and let you know how it goes.
