Going Through Bottles Fast
Old 03-03-2010, 08:34 PM
Greekey's Avatar
Default Going Through Bottles Fast
Wow. I never knew a 10lb nitrous bottle will only last a short period. I swear I must of sprayed 8 times today and my bottle is empty. Is this normal? I see lots of money being spent on refills.
Old 03-03-2010, 08:45 PM
registered user
ScreaminRedZ's Avatar
That sounds about the norm for a 100 shot. I got about 7 out of mine at the track and it was still holding good pressure, but it was hot out that day.
Just out of curiosity, how many pulls did you think you would get?
Old 03-03-2010, 08:49 PM
Greekey's Avatar
Well this is my first time in my life dealing with nitrous and getting it installed on my car. I installed it about 3 weeks ago. I just thought it would last a little longer, then 8 times. Plus I have to drive 40 minutes to get the bottle filled which is a paint in the ***. And I pay 48 to get it filled. Isn't that a little to much to pay?
Old 03-03-2010, 08:51 PM
Zmg00camaross's Avatar
Kind of expensive, buddy filled his for 40 bucks. Stop spraying so damn much haha.
jester ls1's Avatar
Buy the 15lbs bottle, but ya nitrous goes fast, I only use mine when I am in a roll on race or just trying to impress friends.
Old 03-03-2010, 08:53 PM
Greekey's Avatar
I really didnt even think I spray that much. I spray in second, through fourth gear, then I back off. Most of your guys have more then one bottle?
Old 03-03-2010, 08:55 PM
You probly should get 3 15 lbs bottles. at least another 10 bottle since you have to drive so far.
Old 03-03-2010, 08:58 PM
jester ls1's Avatar
Check for leaks!!!
Old 03-03-2010, 10:12 PM
stewaj11's Avatar
Sounds about right, I get a couple less with my 150 shot. And I think I pay about 32 to get mine filled here in Michigan. But there are also shops around me that charge around 60 to fill.
Old 03-04-2010, 08:08 AM
BAKED's Avatar
A 100 shot for 10 seconds uses 1 lb..... That's the rule of thumb at least.
I usually take 6 or 8 bottles with me to the track. It gets VERY expensive when you are spraying a big shot.
Old 03-04-2010, 08:16 AM
registered user
I pay $50 to get mine filled, but there are definitely shops around that charge $60. As fun as it is to spray, I find that I'm ont spraying it as much as I thought I would. Not that I don't like going fast, I just don't seem to need it unless I line up against something mean.
Old 03-04-2010, 08:24 AM
RsSean's Avatar
all my buddies get a 3 to 4 quarter mile passes on the 100 pills, before the bottle pressure is to low. Purge, spary 11 seconds repeat 3 more times.
Old 03-04-2010, 09:45 AM
Nick@HSW's Avatar
And add to that how many times the system is purged too.
Nick
Old 03-04-2010, 11:16 AM
Chris@NitroDaves
Guest
Posts: n/a
For as many times that you sprayed and you saying you spray from 2nd to top of 4th this is normal for the bottle to be empty after that many runs.
Old 03-04-2010, 07:15 PM
Oso SS's Avatar
My 10lb bottle was filled like a year ago and has about 9 lbs left in it. I just never need to use it / never race.
Could be worth buying a few extra used bottles at $100 a pop and having 4-5 filled at a time or buying a motherbottle set up and doing it yourself.
