MSD timing twister or LNC
Old 03-22-2010, 02:09 PM
TA1364's Avatar
Default MSD timing twister or LNC
How do these wire into everything? Which one of these is the easiest to get working right?
Old 03-22-2010, 02:23 PM
tals7's Avatar
Smile
i use the msd twister.it i easy to install as it comes with its own plug in harness.plugs into crank sensor and cam sensor and needs ground +keyed 12 volt hot.hope this helps.
Old 03-22-2010, 03:14 PM
TA1364's Avatar
Where is the cam and crank sensor?
Old 03-22-2010, 04:49 PM
tals7's Avatar
Smile
if you have gen 3 ls1 the crank sensor is by starter and cam sensor is in the back of motor.mine was a wierd set up had to mod the cam plug a little.my set up is a 24x gen 4 ls7 with cam senser in front cover.hope this helps you out.
Old 03-23-2010, 08:34 AM
rambodog's Avatar
There is a third option for timing control. The Timing tuner also plugs into the crank sensor above the starter motor. It also can be used as a window switch.
PM me if you need one.
Old 03-23-2010, 02:43 PM
TA1364's Avatar
Already got a window switch, thanks anyway.
Old 03-23-2010, 04:44 PM
Chris@NitroDaves
Guest
Posts: n/a
The Lingenfelter unit hands down im my personal and proffesional opinion. Also the LNC 002 is a breeze to install and has minimal wiring needed unless you hook up the 2 step.
My vote is for the LNC 002
Old 03-23-2010, 05:28 PM
TA1364's Avatar
Minimal wiring is what I want!
