Refilling nitrous
Old 03-26-2010, 01:55 PM
ColossalCamaro's Avatar
Default Refilling nitrous
I'm looking into doing a nitrous refill station. What is the SAFE way to refill nitrous?
On a completly different note is there a kit someone makes to mount a bottle in the spare tire space in an Fbody?
Old 03-26-2010, 02:39 PM
Nick@HSW's Avatar
Some freeze, some pump...and some do both. I use a pump at the shop to eliminate the need for waiting. Biggest thing you'll want to make sure is that you're running a filter off the mother bottle.
Sparetire Bracket
Nick
Old 03-26-2010, 03:01 PM
Thanks! Where can I find a refill station with a pump?
Is that a plate that bolts in and a bracket attaches too it?
I really appreciate any and all info!
Old 03-26-2010, 03:55 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
We also prefer to pump instead of freeze bottles
Pump station and accessories.
http://nitrousoutlet.com/catalog/cat...=23&section=91
Mounting bracket
http://nitrousoutlet.com/catalog/pro...92&product=963
Old 03-26-2010, 05:15 PM
NOTFAST's Avatar
Freezing is so easy. If you're just doing it for yourself and never in a HUGE rush (have an extra bottle etc) then dont waste money on a pump
Old 03-26-2010, 11:20 PM
Sofls1's Avatar
I wish more shops worked this way. I haven't found a shop in this area that uses the pump to fill bottles. It's a pain in the *** having to drop bottles off to get filled.
Old 03-30-2010, 11:04 AM
What is the procedure for using that refill station?
Old 03-30-2010, 01:12 PM
brandoz28's Avatar
the place that used to do mine preferred to freeze, but they'd use the pump if you were in a hurry
Quick Reply: Refilling nitrous
