Window Switch: Where is the TPS and Tach Signal??
I need help connecting the blue and green wires from the Trick Performance Dual Stage Window Swich to the TPS and Tach Signals. I have tried searching but getting inconsistent information and various years and vehicles.
For a 02 F-Body, where to I tap into to get these connections??
Thanx!
Thanx!
LS1TECH & Trucks Sponsor
TPS = dark blue wire at pin 24 at the red connector on your PCM
TACH = white wire at pin 10 also on the red connector
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
So what was all that green with white stripe on the coil pack and blue wire from your TB all about?
The rest of my Nitrous Kit:
Nitrous Outlet F-Body Halo Kit
Trick Performance Dual Window Switch
Dyno-Tune Air/Fuel Shutdown Switch
Harris Speed Works Bottle Heater
wiring
Thanx!
Thanx!
and the tach is the light green wire with the pessenger side coil conector
check this link :
https://ls1tech.com/forums/nitrous-o...p-00011-a.html
hope this will help
thanks
Guest
Posts: n/a
Male side - - Top row of wires - - second from the left going from the Firewall forward - - It will either be a solid green wire or green w/ white tracer or a turquoise color wire. ( I've seen it all three )
Sorry for bringing it back from the dead
