nitrous purge solenoid bad?
Old 05-05-2010, 07:27 PM
stewaj11's Avatar
Default nitrous purge solenoid bad?
I have a NX purge and I think it might be bad. I was outside installing a pressure gauge on the bottle and after I tightened everything up and turned the bottle on, and I was hearing a hiss. But not from the newly installed pressure gauge. It was coming out of my purge line, if I put my finger over the line I could feel the nitrous leaking out. The only time it stopped was if I pushed my purge button and cleared the pressure from the line. So my question is do I have a bad purge solenoid? It was used when I bought it, but has worked perfect for about a year up until just today.
Old 05-05-2010, 07:29 PM
waterbug1999's Avatar
put power to it and see if you can see anything that stopping it from closing.
Old 05-05-2010, 07:34 PM
stewaj11's Avatar
Do you mean see if there is anything in the way, jamming it? And keeping it from closing all the way
Old 05-05-2010, 07:39 PM
are you saying in between the purge noid and the other noid? Or you mean its leaking out the other side of the noid?
Old 05-05-2010, 07:47 PM
stewaj11's Avatar
It isnt leaking at the solenoid technically. Where the nitrous exits the purge out of a steel tube is where it is felt leaking. Not inbetween the nitrous solenoid and the purge solenoid at all. Does that make sense?
Old 05-05-2010, 07:59 PM
yea.. kind of like something is keeping it from closing all the way.
Old 05-05-2010, 08:10 PM
stewaj11's Avatar
Right, its a slow leak when the is pressure in the line. But when I hit my purge button it opens the purge solenoid all the way and a cloud comes out of it like it should. But then it doesn't close all the way when I release the button.
Old 05-06-2010, 09:16 AM
Nick@HSW's Avatar
99% of the time its debris stuck on the plunger that's hanging it open causing the leak. You can buy a replacement plunger or send it in to NX to have it replaced, just give them a call.
Nick
Quick Reply: nitrous purge solenoid bad?
