NX Solenoid and Purge WTF PICS!!!
I am just getting around to installing my NX nitrous kit, I have had it for a while now. I have an NX kit with what I thought was the iceman solenoid and a Genx2 kit with a purge for the iceman noid.
Can someone please identify this NX nitrous solenoid for me? It has a 1/4NPT port marked "IN", a 1/8" NPT port (that is currently plugged) marked "IN" as well, and a 1/8" NPT N20 port on the bottom for the outlet. What noid is this and how big of a shot is it good to? Below are some pics of it. There is also a capital "P" stamped on the bottom.
My next problem is with setting up the purge. I am assuming the 1/8" NPT on the nitrous noid is for the purge? Does this go to the "IN" on the purge solenoid? If it does it is going to look like complete crap and be flopped 180*. I have a pic below of what it would look like. I hope I am doing something wrong because if this is the way this NX kit is then I am going to sell this stuff and call up N2O outlet or HSW and get a kit instead.
That is an old style Pro Power NX solenoid. Good to about 500 HP
The place the plug is at is where your purge solenoid will attach. Remove the plug and the fitting you have screwed into your purge will connect the two solenoids.
That is in my opnion the best Nitrous Solenoid NX has ever had so no since in replacing it.
However since your solenoids are so old the fuel solenoid probably has an old style piston. This piston is not a good choice for todays pump gas. I would suggest changing out the fuel piston to the new style.
If you need any help or advice feel free to give our tech line a call. We can help you.
Dave
Dave
Thanks for the reply.
I understand that I can unscrew that port, but it seems like the purge valve I have need the "IN" to be on the right side over the left (like it is now). I want the solenoids to be mounted how it looks below instead of all flip-flopped around. No i'm not OCD My enigne bay looks nice and I'd like to try to keep it that way. This may be a dumb question, but can I run feed the purge noid into the "OUT" port? Below is a pic of how I want it to look. (Note: the fitting is screwed into the "OUT" port below)
Here is a pic of the fuel solenoid as well. All of this stuff is new and never used. Would you still recommend replacing the piston in the solenoid?
yeah I really dont want them to be flipped around like that though. I want them to sit how I had them lined up in post #4. Its almost like I need the "IN" and "OUT" ports flipped
Simple fix... Loosen the nut on top of the solenoid. The coil can will then twist freely. Clock the solenoid where the inlet and outlet fittings are in the orientation you prefer and snug back down.
If running pump gas I would upgrade the piston in the fuel solenoid. We have them in stock.
Dave
Dave
This made me lmfao because if you can't figure out the NX solenoids, you'd be just as screwed with HSW or Nitrous Outlet. It's like saying, "I can't figure out how to sharpen my yellow #2 pencil, so I'm going to buy a brown #2 pencil." Maybe you should stick with crayons...
Dave
Dave
That would only solve half his problem, he wants to know why the stamping for the smaller purge solenoid would have to be facing the opposite direction as the larger nitrous solenoid. He's very very meticulous and even something as small and minuscule as this would bug him, the rest of his car is mint. Good luck with the rest of the install Ryan.
Dave
Dave
thanks for the pic! that looks well-done. I like how you have nice and short lines running from the solenoid to the plate.
I am also wondering if it is more effective to have the purge solenoid connected to the nitrous solenoid over a setup like above where it is before the solenoid?
That looks nice! I plan on rotating the top. i would just put it on the other side, but since I have the bigger noid, the inlet for the feed line is 1/4" NPT and the purge is smaller, 1/8" NPT.
I really do like that mounting bracket!
Just go with an adapter like the inline one I have connecting them, 1 side 1/4npt, other side 1/8npt. Should be no more then 4-5 bucks.
The bracket made it nice. When I clean everything up under there it looks really good. Just tough to keep the dust off since I dont have the vent blocked on my ss hood.
Austin
Austin
