Changing Braided to Hardline N20(First time plumbing)PICS
Old 05-18-2011, 08:25 PM
1904gto's Avatar
Question Changing Braided to Hardline N20(First time plumbing)PICS
so ive wanted to get into plumbin direct port kits and other hardline systems for awhile now and ive gotten my fitting in and bender just waiting on my flare tool. but i just bent couple lines today, thought it was decent for my first time.feedback would be appreciated
would really like to get good at this.
anywhere here are pics
induction solutions ftw!
Old 05-18-2011, 09:20 PM
Reaperchild's Avatar
Hey I'm no expert but I couldn't tell it was an inexperinced job !!
Thumbs up =)
Y didn't you go with braided flex hoses instead of the steel lines?
Old 05-18-2011, 10:20 PM
Ph.D. in HUBRIS
custm2500's Avatar
Looks good. Not sure I like the big swooping curve but it certainly doesn't look bad.
Why do you have two nozzles? I have never seen two nozzles and only have one kit. Did you have a seccond at some time?
Old 05-19-2011, 01:28 AM
minytrker's Avatar
Thats how the old power ring kit was, two nozzles in a metal ring.
Old 05-19-2011, 11:09 AM
cbr600rx7's Avatar
Looks good and the hard lines look way better then braided. What bender did you use.
Old 05-19-2011, 04:04 PM
1904gto's Avatar
thanks everybody and i used an imperial bender i got at grainger for 55, discounted tho works well also got a cheap one for closer bends and it helps
and this is a old TNT kit gonnna finish it up today
Old 05-19-2011, 04:05 PM
1904gto's Avatar
Thumbs up =)
liked the cleaner looks and to practice pretty much would like to get into plumbing up for direct port kits etc. for friends n people
Old 05-19-2011, 04:10 PM
Race your car!
JL ws-6's Avatar
Looks pretty good. Get the other side done, and a hard line from the fuel rail to the solenoid, and it will look really good.... new stickers on the solenoids would make it even better
It's something that does take alot of pratice. But, be glad you can just do a 37 degree single flare with tube nuts.. double 45 degree flares suck compared to using the 37 degree/tube nut deal
Old 05-19-2011, 04:48 PM
Chris@NitroDaves
Guest
Posts: n/a
Not a bad job for the first time. I agree with JL ws-6...now that you have hardlined that i'd go further and hardline the rest.
Old 05-19-2011, 06:38 PM
IWGF's Avatar
Looks pretty good!
Old 05-19-2011, 06:55 PM
1904gto's Avatar
thank you appreciate it, i did the other side but i ran into a little problem with
the nitrous main line and purge line, i just got this done for now untill i think of an other idea to get around this, or if you guys could chime in with some
here are some pics
thanks for input and advice
Old 05-19-2011, 09:12 PM
Race your car!
JL ws-6's Avatar
Hardline the purge. You really should have the purge solenoid right at the nitrous solenoid, so that way you're not wasting a bunch.... then you'd just have to run a hardline purge line out of the engine bay.
Hardline that fuel feed too, it will look a TON better with that loop of line out of there for that side. I think that's a 1/4 inch line you need there with a -6 fittings, if I remember right. Been a while since I have done one of those but I think that's what it was. Could be wrong though.
Old 05-20-2011, 04:37 PM
1904gto's Avatar
ok cool thanks!
Old 05-22-2011, 02:19 PM
1904gto's Avatar
just changed purge location
Quick Reply: Changing Braided to Hardline N20(First time plumbing)PICS
