what kind of fuel pump to get with nitrous
what kind of fuel pump do i need have the stock fuel pump in now and was told 100 shot would be okay on that but i want to go bigger i want to go 150 so does anybody know what kind of fuel pump i need?
also what do you guys think about this fuel pump will it be enough its a cammed ls1 with forged pistons the specs on the cam are 232/234 595/598 112 lsa
http://www.ws6project.com/user_stor/...rts-fuel-pump/
You will be fine with a walbro 255 and replace your fuel filter will your under the car. Your safe up to a 150 shot with that walbro 255 pump with good plugs and right fuel. There are people doing more spray but then you need to be on your A game with timing,plugs and knowledge
Also with your cam you when you have someone tune it look at your injector duty cycle and see if your maxing out the injectors.
Let me know if you need anything else.
