plug? ??
plug? ??
I use to run 12.0 on motor and since I hook the nitrous up and change plugs to br7ef gap 33. I run 12.4 or 12.5 on motor and 11.1 on spray 150 shot. Is the plugs too cold for n/a? Or my tune bad? Don't know nothing about tuning. I have a timing tuner for the nitrous.
your tuner took some timing out of your tune for the nitrous, the number 7 plug is a good choice. Switching to that plug should not rob any power at all, its more so the timing that has been pulled for the 150 shot.
The motor wants what it wants the only way is to verify if the plug is telling you the motors happy, I tuned a buddys car with full boltons and a 150 shot with 7 plugs and ended up with 26 degrees total on the kit but its what the motor wanted 25 doesnt sound out in left field
But dont just start at 25 always pull more than you think you should and you can work your way up, every combo is different, but if you want help reading plugs there are plenty of us here that can help to get you were you need to go.
