Fastest Stock CI N20 car ever!
LOL weve been holding back because the combo was so fresh it had tons of bugs to work out, and theres already a few similar threads but we figured it was time for our thread, think weve just about go the bugs worked out on this car and its about to fly.
combos is
stock ls6 intake
afr 205 untouched heads
Protree Built 347, (stock 97 block, stock crank, callies rods, weisco pistons)
Th400
12 bolt with 3.73s
Pump gas on the motor, C16 in the stand alone for both stages
Nitro Daves wet kit and a Modified NXL fogger
200 in the wet kit, 250 in the fogger
Car Weighs right at 3400 with a driver and bottle and gas (raceweight)
no light weight suspension parts on this car, its missing ac/heat/cruise/backseat thats it! Cars tagged and inspected and driven to work!
stock kmember, lower a-arms, ps, rack, struts, springs, seats dash + a MS cage
So far weve been a 9.55@147.6, wihich i believe makes us the fastest Stock cubic inch nitrous ever. that pass had a 1.44 60' normally we 1.32~
If we get the car to RPM out the backdoor and stick we should be on 8's doorstep. Hoping to find out tomaro!
Thanks to the people that have helped us out sofar
Nitro Dave
Sam (Sam88gta)
Louis @LG
combos is
stock ls6 intake
Th400
12 bolt with 3.73s
Nitro Dave
Sam (Sam88gta)
Louis @LG
9 Second Club/Nitrous Mod
https://ls1tech.com/forums/nitrous-o...rous-list.html.. Ya'll newbies need to learn how to read the stickies. Also, the stock cube record holder isn't even a f-body/vette. You can put a ls1 in a go cart to make it go 9s.. Just my opinion.
There is so much weight put on the "the fastest" blah, blah, blah. I am the fastest H/C/I + nitrous stroker motor in Germany. Bring it back to the states, and I am the slowest again. Anyways, awesome ET and MPH. I would put the pig on a diet though.
8 second mod
that is good mph for sure. however with bad short times you gain mph in most cases. my vett on street tires went 12.0 at 116, then 12.0 @ 128 with 100 shot. put drag radials on it and it went 11.4 @ 124
either way thats good mph
