nitrous for procharged lsx?
Old 06-20-2012, 04:21 AM
usnfenix's Avatar
Default nitrous for procharged lsx?
currently swapping a forged ls1 into my 79 vette, and i will be topping it off with a F1 procharger, aiming for 600+rwhp. is there a nitrous system i can fit for a small shot (no more than a 50 shot) that will work with the procharged setup? would not be spraying all the time would only be spraying on a rematch when the previous run was close.
Old 06-20-2012, 09:25 AM
Neal@NitrousOutlet's Avatar
Most systems can do that low of a shot. I know that our plates and nozzles will do 50 hp. Just remember that that 50hp jetting will add close to 100hp with a supercharger
Old 06-20-2012, 09:30 AM
Ellsworth's Avatar
An F series procharger for 600rwhp? I would think a D1SC would work better?
Old 06-20-2012, 02:25 PM
usnfenix's Avatar
well 600 at the minimum, more will be welcome of course.
so how would it be better to spray? dry, wet or direct? im thinking right before the TB would prob be best right?
Old 06-20-2012, 03:43 PM
no reason to go direct and 50 jetting. A plate or nozzle should be great for the amount of nitrous. Wet most likely will be easier. You have to take into account that with the dry you are going to possibly need more injector so wet might be a little easier and cheaper to do.
Old 06-20-2012, 07:48 PM
usnfenix's Avatar
so just any basic (quality of course) wet kit will do it? no special mods to be done? what about tuning should there be a special tune or just the supercharge tune ill be getting and it will be fine to spray every now and then
Old 06-20-2012, 08:18 PM
Fbodyjunkie06's Avatar
With just a 100hp shot you may just be able to add race gas such as C-16 or VP N2O and spray the shot without pulling any timing.
If you don't want to mess with adding some race gas you will need to pull 2-4* timing most likely 2-3*.
Old 06-25-2012, 12:02 PM
+badss+'s Avatar
Good info I was thinking of adding a small shot to mine to help 60 better or for a rematch race
Old 06-25-2012, 02:41 PM
ShiznityZ28's Avatar
Nitrous+boost=pimp.....
Old 06-25-2012, 03:46 PM
Nitro Dave's Nitrous Outlet's Avatar
Our single nozzle systems and plate systems will jet down as low as 35 hp.
Plan on pulling timing. And if you start upping the jet odds are you will need to go to a colder plug etc.
Something as simple as our Brand X single nozzle system would keep the price down and provide all the power you need with out sacrificing quality.
To do it right you will need to plan on purchasing the needed accessories and safety items as well. Plan to spend between 800-1000 dollars.
Dave
Quick Reply: nitrous for procharged lsx?
