Stock short block LS2 spraying into the 8's
Old 09-10-2012, 08:48 PM
mactizen's Avatar
Default Stock short block LS2 spraying into the 8's
Finally able to present my efforts for the year, big thanks to nitrous outlet and PatG.
Quick specs are :
stock bottom end gen4 LS2
ported 243's
PatG spec'd camshaft
stg 1 direct port fast 102 by Nitrous Outlet (28n24f)
stg 2 nitrous outlet plate (not yet in use)
FTI converter
th400 by Hutch's
8.8 narrowed by DTS, moser 35 spline spool and axles
edit - I also run a competition nano kit which has improved consistency 10 fold over last year.
http://www.youtube.com/watch?v=7rOXb...ature=youtu.be
Old 09-10-2012, 08:58 PM
Old School Heavy
speedtigger's Avatar
Holy cow! That has to be the fastest stock shortblock LS. Congratulations. How much does that Rx weigh? And, post a timeslip.
Old 09-10-2012, 09:02 PM
mactizen's Avatar
by my count it's the third fastest and the third one in the 8's, but we're working on that.
its just about 2600 haven't weighed this year
Old 09-10-2012, 09:20 PM
Sales1@Texas-speed's Avatar
Congrats! That is definetly moving!
Old 09-10-2012, 09:50 PM
Old School Heavy
Pretty impressive for the stock short block to take a 250 shot like that.
Old 09-10-2012, 10:09 PM
fergymoto's Avatar
Nice. It's all in the tune up.
Old 09-11-2012, 08:44 AM
87silverbullet's Avatar
There are plenty of stock bottom ends taking way more than that right now.
Old 09-11-2012, 08:59 AM
SargeZ06's Avatar
Is there a difference in stock bottom-end and stock short block? I see some people wording this so carefully sometimes that I just wonder what they actually are.
So in this case is the stock bottom end, stock crank, pistons, rods, rod bolts? Other than the cam, and maybe chain and oil pump, was anything else changed?
Old 09-11-2012, 09:05 AM
Old School Heavy
Way more? Who is spraying way more on a stock short block?
Old 09-11-2012, 09:39 AM
dnkynrbk's Avatar
Congratulations man
Old 09-11-2012, 09:46 AM
mactizen's Avatar
Unlike other cars that have posted fuzzy *** videos with big claims, I have nothing to hide, the rotating assembly and block is 100% stock with opened up ring gaps, I have a ported Ls6 pump and H3 oil pan and pickup the ported 243 heads are the same ones gm bolted on at the assembly line I have arp headstuds holding them down tho.
Old 09-11-2012, 09:51 AM
mactizen's Avatar
Aside from Carter01 I'm not sure of many, but anything is possible I assume.
Old 09-11-2012, 11:41 AM
cyipher's Avatar
I dont call this stock bottom end then, tight ring gaps is part of the problem in ls based motors and one of the challenges that you work around. It is impressive though to see what stock parts can do but what you have is not a factory stock bottom end.
Old 09-11-2012, 01:40 PM
Minytryker, Camscam, fbodyjunkie and a few others I can't think of.
Old 09-11-2012, 01:45 PM
That's your opinion and you are entitled to it.
I consider a stock bottom end if it has stock crank, rods, and pistons. Rings and bearings do not count in my book, but thats my opinion.
Old 09-11-2012, 02:25 PM
mactizen's Avatar
I don't follow along close enough here but it's good to know other ppl like to live on the edge and do what alot of ppl say will "instantly melt the pistons" and prove it can be done. As was mentioned it's all in the tune and being patient, for me it's also all in the suspension tuning which I've been working diligently at for 3 years. That 1.27 60' I'm very proud of.
Old School Heavy
How much do you think they are spraying?
Old 09-11-2012, 03:23 PM
SargeZ06's Avatar
No no I'm not saying you had something to hide. I'm just trying understand what everyone excepts as stock bottom end. Just trying to see how you got there. Trying to learn from people who are doing things like this.
Good work.
Old 09-11-2012, 03:26 PM
SargeZ06's Avatar
That's kinda how I feel.
Old 09-11-2012, 04:35 PM
camscam02's Avatar
Congrats man! That is awesome. Flying!
And yes we spray a lot on ours. 300-350 for the past 2 years
Quick Reply: Stock short block LS2 spraying into the 8's
