Nitrous Outlet Puck Results
Old 09-24-2013, 09:30 AM
brandon@nitrousoutlet's Avatar
Default Nitrous Outlet Puck Results
Blue-Motor
Red-150 shot
Green-250 shot
Purple-300 shot.
Test Vehicle Info:
Brian Lynch's 1998 Camaro Z28
383 LSX
11.8 to 1
Comp Cam
Eagle rotating assembly
PRC 2.5 heads
Super Vic intake
Complete Nitrous Outlet Puck system
TH400 with Trans brake 4500 stall
Strange 12 bolt rear with 3.73
Old 09-24-2013, 10:02 AM
Rise of the Phoenix's Avatar
Damn, that's getting it done. Not to mention one of the best looking Camaro's I've seen. I guess that motor is built to handle a 300 shot all day long?
Old 09-24-2013, 11:04 AM
Nitro Dave's Nitrous Outlet's Avatar
I have said since the day we released this thing. Its awesome!
Old 09-24-2013, 04:57 PM
Moderator
LIL SS's Avatar
Great numbers.
What jets were in the 250 and 300 hit tune ups?
Old 09-24-2013, 06:21 PM
150 hp jet is .062
250 hp jet is .088
300 hp jet is .093
Dave
Old 09-24-2013, 06:35 PM
HCI2000SS's Avatar
Damn that thing must be a monster! I'd like to throw a 300 shot at mine, but somehow I think my 10 bolt would not be so happy lol
Old 09-24-2013, 06:58 PM
Moderator
LIL SS's Avatar
I am going to wager the car needs a gear change assuming 28" tall tire. But not a bad problem to have.
Old 09-27-2013, 04:32 PM
Hey guys heres some more Puck results. Its not an LS but look at that torque curve!
Motor is a Ford 408 with untouched Victor JR. Heads.
Old 09-29-2013, 12:17 AM
Moderator
LIL SS's Avatar
Yup.. Lower the rpm, the more tq it makes with equal jetting. 250hp is 250hp regardless of rpm. 250hp at 3800rpm is 345ftlbs.
Old 09-29-2013, 02:44 AM
navyblueSS's Avatar
Nice!
Old 09-29-2013, 03:45 AM
Heavy H.P.'s Avatar
Would it be safe to say this would be a easier setup to go with then a Direct Port?
Old 09-30-2013, 11:59 AM
Yeah probably. What size shot are you looking to run with it? Where a direct port really shines is being able to fine tune each cylinder as far as A/F ratio and getting a very even distribution across all 8 cylinders.
Old 10-02-2013, 02:19 AM
Heavy H.P.'s Avatar
Originally Posted by brandon@nitrousoutlet
yeah probably. What size shot are you looking to run with it? Where a direct port really shines is being able to fine tune each cylinder as far as a/f ratio and getting a very even distribution across all 8 cylinders.
250-300
Old 10-02-2013, 08:35 AM
250-300
Thats perfect for the Puck!
Old 10-02-2013, 09:15 AM
JAX04's Avatar
****, first time i been in the nitrous section for awhile, that puck is bad ***, lol. Just watched the video you have, that is sneaky little deal right there!
Old 10-02-2013, 09:28 AM
Heavy H.P.'s Avatar
Only issue is I don't have a Vic Jr. I been thinking about it but don't know if it is worth doing on my setup.
Old 10-02-2013, 10:03 AM
bernarlitt's Avatar
nice results brandon! are you going to keep spraying it with the 300 shot?
Old 10-02-2013, 01:08 PM
What else is needed to make it a complete kit? Just the bottle and feed line?
Old 10-08-2013, 05:17 PM
You still need solenoids and lines going to the puck in addition to the bottle and main feed line.
Old 10-08-2013, 05:20 PM
Tell me some more about your combination and what you're looking to do with it?
Quick Reply: Nitrous Outlet Puck Results
