what are these nitrous parts?
I purchased a complete nitrous and NANO kit that a guy who bought it from Nitrous Outlet but changed directions and didn't need it. All parts were new in the box and even the receipt was included.
I've mocked everything up and am almost ready to wire but had a couple small items left over. The kit was specifically for a C5. The two black fittings (they are the same) as well as the silver one were in the box with the FPSS I believe. I simply screwed the FPSS directly into one of the ports on the fuel log that is attached to the scrader valve and it doesn't appear that I need any of these.
Does anyone know what these parts are as well as what the hard line is for?
Scott
Scott
Scott
Scott
hard lines to connect ur noids if u got it all hooked up no worries, and the 2 black fittings are for main line( bottle to nitrous noid) put it on ur bottle first and then ur main line,its used to put a pressure to see what pressure ur bottle has very important. also can be used for fuel pressure attach to ur fuel rail and put a fuel pressure gauge. all u have to do is back that allen bolt out. silver looks like a hose end fitting if u can take that nut off it i can see it better. cant really tell. but u dont really have to have this stuff. on the hardline if u got it all hooked up and plumbed in correct then no need for it.
Thanks!
Scott
What's that mean Brandon? And should it be installed on my bottle and if so where? What's it do? I already filled the nitrous bottle and NANO bottle and have them in the car and connected. Will I have to empty one or the other?
Thanks again.
Scott
Thanks again.
Scott
Tar Heel. Note, its a CHECK VALVE. That way if you decide to pull off the NANO bottle, your nitrous bottle will still hold pressure. This might also allow you to remove a nitrous bottle and use up a nano bottle that has pressure remaining.
Suggest you post a picture of your setup.
I think I have it now. When I filled my bottles I filled the NANO first with the flexible braided line attached to it. With the valve closed nothing came out. We then went to the nitrous shop and the owner said when he filled it nitrous would come back out unless we had something to put in that port. We just went ahead and attached the NANO bottle there, had it filled and all was fine. Kind of a pain carrying the two bottles together especially full. I'm guessing then that check valve goes on the nitrous bottle and will allow me to take the nitrous bottle out without removing the NANO bottle.
Scott
