150 shot vs 175 shot results
I was kind of surprised and very happy with the results as I finally went up in jet. I'm pulling 4* timing with the LNC2000 on the 150 shot and pulled 5* on the 175 shot.
Here's some video of the passes
10.23 pass
Same pass, from my car
10.01 pass
10.05 pass
10.23 pass
10.01 pass
10.05 pass
Very nice, I'm thinking of installing one of those lnc 2000 controllers. I have heard it works off the coil harness. Does it take place completely of the factory harness coil plugs?
I told you to take out the passenger seat! Drop the 20 pounds and it would make it : )
PS: That was my 2nd pass with the TH400. I honestly forgot about having to shift, needs more 4L60E.
LS1Tech Premium Sponsor
What times were you running?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
great car
9 Second Club/Nitrous Mod
We were going of the Nitrous Outlet jet chart which says a 73 jet is what should be used for a 175 shot. Either way we are happy that the car runs so well and is so consistent. With a little b it of tweaking I think we can run a 9.9X on the 73 jet so we will probably leave it in for a while.
www.robietherobot.com
The Fuel jet size should be 0.037" or 0.948mm
A Nitrous jet size of .073" or 1.8542mm should produce:
240.66 HP with 1 port(s)
Actual HP to the wheels: 204.56 HP
Fuel jetting is a different story..
I would ditch the tr6s plugs and put in #8 (1049) non-projected plug, especially on a 73n jet.
A lot of companies rates their jetting different:
