Nitrous activation
button allows you to launch at full throttle then hit the nitrous. but i use a microswitych. i launch full throttle, then turn on hte power switch. then once the run is over i let off the throttle. which in turn turns off the nitrous.
So isn't that basically a WOT switch?
I have a switch that I rigged up at the throttle body, it gets pushed when I am either at WOT or like 98% there. I have that WOT switch then an arming switch inside the car. Would that be considered a "button" switch?
I use a microswitch ... Its really easy for me to modulate that last little bit of the pedal where the nitrous kicks on.. If the tires spin, I back off just enough to kill the spray, then get back in it when it hooks.. A LOT easier in a six speed than trying to fumble with a button, steer, shift, and hit pedals Its just like driving normally, with a touch more power.
this micro switch..with my NX kit the WOT switch looks like a computer chip thing with a big arm that hangs off the top and when pushed down it clicks...how do i install this? is this what you guys are talkinga bout putting on the TB?
I just want to spray is in 3rd and 4th and I don’t want to be flipping a switch either and I want to WOT switch so any one of you wired up a gear selector switch as well to do this just trying to get an idea to do it cause I know I will not keep it planted in 1st or 2nd if I spray it of this is in my V8 MGB so anyone got any ideas?
