Simple wet kit relay wiring help
I have been in the process of installing a nos wet plate kit on my trans am, and I am trying to get the baker electronix window switch to work. My relay and solenoids are working right now. I have the 12 v with fuse ran to the 30 post, the ground to the 85 post (split with the white wire/ground from the window switch) the solenoids are run to the 87 post and the wot switch is on the 86 post.
I just need some help on what posts on the relay to connect which wire to. Just a simple single relay, wot switch, arming switch, and two solenoid system.
Ls1tech & Truck Sponsor
So on the window switch, you've got...
red- 12v ignition
green- going to non common color on ignition coil
white- going to ground prong (85) on the relay
black- straight to ground
and it isn't working?
-Garrett
red- 12v ignition
-Garrett
My problem was I had the 85 connected to the white on the window switch AND a separate ground.. So the relay was always grounded. Didn't realize that's how the switch worked. Works great now!
