Question on setting up a Fogger system
Going to run a fogger with a stand alone fuel cell using low psi. Question is. For changing the shot size, Instead of changing all 16 jets(2 per nozzel, 8 nozzels) Can you do adjustmets at the noids? This way you could change 4 jets instead of 16. Any suggestions are appreciated. If so is there a jetting chart to show this?
Ls1tech & Truck Sponsor
No, you'll have to change out all the jets. There isn't really a way to make adjustments at the solenoids, and then it wouldn't be a very effective direct port. One of the advantages of a true direct port is having the ability to tune each cylinder independently.
You can make changes to the fuel pressure to lean or richen things up also.
-Garrett
-Garrett
