one burnt plug
one burnt plug
any of you guys running the nxl kit burnt any plugs? just pulled mine out the other day and number 7's electrode was melted. all the rest of the plugs look good. anybody have any ideas.
is it possible you put the wrong fuel or nitrous jet in that cylinder, or could you have used too much sealent in the fuel side connections and that is blocking the fuel? I don't have mine running yet, but that is just something I thought could be bad news when I was installing it the other night. Good luck Brian
just 120 for right now, on the dyno i had good air fuel ratio. I will check the jets when i get off work, i didn't even think about that ! thanks. i will let you know.
Originally Posted by LOnSLO
I will say this. If you are using a stock type fuel system, I have seen number 7 cylinder burn up on several different cars.
