Contemplating an -8AN feed line? Read this first!
This is some info that Dave gathered regarding the flowing pph levels of one of our foggers hooked up with an 8AN Feed Line Vs. a -6AN Feed Line. Check it out!
-6 AN VS -8 AN
When does a bigger main feed line help flow vs hurt flow? You may be surprise to discover bigger is not always better. I have racers always calling me wanting a 8 AN feed line on smaller tune up applications because they were told it would increase flow. So today I am going to provide you with a comparison flow data of -6 AN VS -8 AN.
The direct port intake that we are using for comparison flow data has .122 Nitrous solenoids and .187 fuel solenoids feeding SBT nozzles.
The only thing we will change when swapping to an 8AN feed line is the Y and the feed line.
The System was flowed at 850 psi
You decide if its helping or hurting flow.
-6 AN
.026 Jet = 792 PPH 30 PSI Drop
.036 Jet = 1360.8 PPH 59 PSI Drop
.041 Jet = 1706.4 PPH 58 PSI Drop
.057 Jet = 2642.4 PPH 93 PSI Drop
-8 AN
.026 Jet = 691.2 PPH 36 PSI Drop
.036 Jet = 1245.6 PPH 51 PSI Drop
.041 Jet = 1778.4 PPH 74 PSI Drop
.057 Jet = 2692.8 PPH 103 PSI Drop
-6 AN VS -8 AN
-6 AN
-8 AN
Whats the volume difference between a 14' 6AN & 8AN feedline? Moving from dual 4s to dual 6s made me really notice how much nitrous is left in the feedline and being wasted on bottle changes. ..another factor to consider.
The lenth of the hose and fitting arrangements will alter how much the hose can flow. Most nitrous systems come standard with a 14 to 16 ft hose. I have found that the 4an hose that long starts suffering around 225 to 250 horse power. Switching to a 6an at that point will improve the flow rate of the system.
Dave
Dave
like to see a test done with 4an and 6an. im at the point some ppl say a 4an is hurting me and some say i got 50 hp to go before i need a 6an. i think what hurts some of these kits is going to a 3an after the noid. my kit is a nx plate and noids with a 4an line from start to finish all straight lines no angles and 12' long. been told i need a 6an to flow 200-225 and some say im fine till 250 maybe more.. i got a bet going to see if the 4an will support 200 on a dyno pull. will know in a few more weeks
There were no adapter or reducer fittings used in this test. The only thing changed was the Y fitting, feed line and bottle nut. It was changed from a 6anX6anX6an Y to an 8anX6anX6an Y fitting. The bottle nut went from 6an to 8an.
I actually saw different results with my car... We had to change to -6 for Ultra Street. I log nitrous pressure at the bottle and after the solenoid... -6 to -8 caused the pressure drop to go up almost 70psi. Also all my tunes(78 jets and higher) were fat....
u can see in his test the bigger the jet the less diff they are so id say u could be at the gainning point with a .078 jet.
each test the flow gets smaller differece as the jet goes up
Well if you guys get bored you can flow test a Singer Plate with a -4 vs -6 and let me know how much I'm losing with a 99 jet.
I'm restricted to a -4 feed. I have 4' line to a 1/4 turn valve then another 4' line to solenoid and -4 lines from solenoid to plate is what Lance and Dave came up with. I'd like to know if there's more on the table for the days I'm not "Class" racing
Our complete feed has to be -4. I've never tested anything lol, just started using the stinger recently
-6 AN VS -8 AN
-6 AN
-8 AN
-6 AN VS -8 AN
-6 AN
-8 AN
in the data.
The .036 test flows 1360.8 PPH with a 59 PSI drop.
The .041 test flows 1706.4 PPH with a 58 PSI drop.
If the starting bottle parameters for both tests are equal (volume/weight
and pressure/temp) I find it difficult to understand how the results
show a 25% (346/1360.8) flow increase while bottle shows
a decrease in pressure drop. (59 vs 58)
What's your thoughts?
