75 shot on H/C/I WS6
just bought a WS6 had plans for trick flow GenX heads fast 92 intake 3.73's and MS4 cam from texas speed with supporting mods. would running a kit with 75 hp jet hurt the motor at all? if not what kit should be recommended on these LS1's?
Ls1tech & Truck Sponsor
I would check and see what plugs are in there, and also you will want to probably pull timing 2* per 50hp for your setup. You can do this in HP tuners and change tunes back and forth, or you can pick up one of these and pull timing on the fly only when the nitrous system is armed.
http://www.lingenfelter.com/mm5/merc...3#.VWSeUEZyL5U
Here is the links to those other accessories I was talking about.
http://www.nitrousexpress.com/18959-...-required.html
http://www.nitrousexpress.com/15940-...-4-14amps.html
Thanks,
Garrett
This is correct. And just for reference a 75hp shot is a fairly small amount of nitrous, so I wouldn't be too worried about it if it was my car. I would put an RPM window switch and a bottle heater on it for both safety and performance. If you have anymore questions feel free to ask.
Thanks,
Garrett
Thanks,
Garrett
If you have enough injector & fuel pump to support it you could just fog the airbox (dry in front of the MAF). A competent tuner can make this work really well and will save you a bunch of money.
Dry kits can be put together for next to nothing and no need to buy a timing retard device as your PCM (properly tuned) will pull the timing and add correct fuel upon activation.
reply fly cut
I fly cut mine .095 on factory pistons , spraying 200 shot , over 100,000 mile on the bottom end, just check ur plugs often and don't get greedy with timing
