Blowing purge push buttons
So I'm having a problem where I've gone through 2, 8amp purge push buttons and I don't know why. I have everything wired up as they tell you to in the instructions the only thing I can think of is im using my headlight switch as a second arming switch could I be drawing too many amps from my headlights that it's causing me to blow out the purge push buttons?
Ls1tech & Truck Sponsor
Is the purge still working? The purge might be burned up. The coil inside will melt together if it gets too hot from being activated too long and then it will draw a significant amount more amperage. (Which could explain why the fuses keep blowing.)
Thanks,
Garrett
Thanks,
Garrett
The coil doesn't smell burnt at all and it doesnt even feel hot. I dont understand how I could be burning up these push buttons. I just put in a 15 amp spring loaded toggle switch if this burns up then I have something wrong.
i don't think the solenoid is burned up at all since it works fine both times after I changed the push button. And when I purge I only hit it for maybe 3 seconds each purge nowhere near the 20 seconds it say it takes to burn the mood up. but after doing that for the 3 passes I did, the push button would no longer work.
That switch that you put in should handle the load fine. Most purges will pull up to 10-12 amps, regardless of who makes them. A majority of the push button switches though are only rated for 3-4 amps, so they may work a few times, then burn out. Personally, I'd still run a relay just to be on the safe side with wiring. If you have any questions or have any more problems with it, feel free to PM me and I'll do all I can to help you get it worked out.
Ok so I took my car to work tonight so I could hook my multimeter up to it and see how many amps it was drawing. The biggest spike was 2.6 amps so now I'm completely stumped as to why I blew out two buttons. My only idea is that the push buttons I bought from aytozone were crap I didn't use the one that can in the kit because the one tab was broken off of it but I didn't have the patience to send it back and wait for a new one. Do you think these aytozone push buttons could be the problem even though they say they're rated for 8 amps?
-Garrett
Key work buddy AUTOZONE. I went thru the same thing on my switch, blaming everything else and all it was the cheap *** button. I bought a TCI transbrake button and never had an issue again. Yes the autozone switch was only about 10.00 I think, the TCI was about 45-60. Been awhile, but never had a problem again.
Is the switch rated at 8 amps ac or dc? Many times switches are rated at an ac amperage. If rated for ac, the dc rating would be much lower. Probably around 2 amps. Iirc, my NO purge is around 8 amps. Plus, your probably not capturing the in rush "spike" current, which then drops as the magnetic field saturates and then stabilizes.
